programming keyfob
Old Sep 27, 2006 | 01:30 PM
Stalldaworld's Avatar
programming keyfob
i have searched please dont flame...
can i get some instructions on how to do this
please
thank you
Old Sep 27, 2006 | 01:37 PM
NewLoveI30's Avatar
Try searching in the How-to's and FAQ's.
Old Sep 27, 2006 | 01:45 PM
NewLoveI30's Avatar
Ok after a quick look through the How-To's I could not find it anymore...
I was able to find it within about 20 sec. searching the net though. Here you go:
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try. Good Luck
Remember, Google is your friend!
Old Sep 28, 2006 | 09:02 AM
BewstAdd1ct's Avatar
AAAHAHAHAHAAHAHHAHAHAHAHAAAAAAAAA
:breathe:
AAAAHAAHAHAHAHAAAAAAAHAHHHHHH
liek omg its teh farking fountin of youth!111
Old Sep 28, 2006 | 09:21 AM
Maxfli's Avatar
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it...
...86 steps later...
...turn key off and unlock door and get out and try. Good Luck
and do the hokey pokey and turn yourself about, and that's what its all about!!
Great info NewLoveI30...I just hope I never have to reprogram my remotes cause it would probably take a while!!
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
flu2000
Sep 14, 2015 12:34 PM
