front sway bar links
Old Oct 30, 2006 | 03:01 PM
joeyd's Avatar
when i turn my steering wheel all the way to either side i hear a loud clunk clunk sound...i heard it is the sway bar links?...is this true..also how hard is it to change these, and where should i get them from?
Old Oct 30, 2006 | 04:00 PM
xnyc's Avatar
lube your bumpstops. it is a little metal rod that sticks out from your steering knuckle. it is usually covered by a plastic cap. if your car is serviced at the dealership, it is usualy lubed by the tech. its also not unusual for the cap to come off. get some brake lube or grease and lube up the cap and the metal plate that it makes contact with.
Old Oct 30, 2006 | 04:43 PM
super6's Avatar
yup the brake stops, check to see if they are still there or broke off $3 at dealer. good trick id put them in hot water before putting them on, other wise they are just a bit small and will crack.
if its not that then yes, check the tie rod ends and sway bar end links.
Old Oct 30, 2006 | 04:56 PM
dansmax2003's Avatar
Replacing the end links is EASY! My car's front end was making weird noises when turning and going over bumps. People from this forum told me that the reason is bad sway bar end links. I replaced them and things are just fine now. No noises, no clunks,...car is back to normal.
I replaced them myself. You need to lift the car on jack stands (on both sides), remote the front wheels and you'lll see them.
Make sure, when you put the new end links, not to forget any washers.
You can buy the end links from here... $16/each
http://oem.thepartsbin.com/parts/the...%20Kit&dp=true
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
MaxStock
Aug 14, 2015 10:03 PM
