Need help with oxygen sensor issue
Old Dec 10, 2006 | 08:49 AM
wyche89's Avatar
Hey guys, I have a 2001 max with the SES light on. I went to auto zone to have it scanned, and the code was P0160, which according to the haynes repair manual translates to: "rear heated oxygen sensor circuit (bank 2)." On the receipt from auto zone it says oxygen sensor 2, bank 2. And I need to know which one that is, because I have a cali-spec car which has 4 different oxygen sensors. So which one do I replace? Also, since it says "circuit," does that mean I can get away with just replacing the circuit where it plugs in up top under the hood or do I have to replace the whole sensor. I checked the stickies, but couldn't really find anything. Thanx alot.
Old Dec 10, 2006 | 11:56 PM
Imax00's Avatar
same here
I have the same problem Im not sure if i can replace 1 sensor or if i have to replace all of them. The guy at autozone told me to replace all but i dont have the funds right now to attempt that...just finised christmas shopping.
Can we just change 1?
Old Dec 11, 2006 | 04:34 PM
foodmanry's Avatar
Da Roller Coaster!
You have to replace both rear O2 sensors.
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Old Dec 11, 2006 | 07:42 PM
RLW001's Avatar
Same here, I only replaced 1 sensor (the blue one that I messed up changing my y-pipe) and no more SES.
Old Dec 12, 2006 | 06:27 AM
steves01max's Avatar
Change them all.
Old Dec 12, 2006 | 11:58 AM
foodmanry's Avatar
Da Roller Coaster!
Follow the TSB...RLW001 had a special case as he damaged the one O2 sensor which threw a code.
Steves doesn't really know what he is talking about.
Old Dec 12, 2006 | 02:09 PM
wyche89's Avatar
ok, i went to the nissan dealer and told the guy what the code was and he showed me a diagram and showed me which one to change... if you look in front of the engine where all the oxygen sensors are lined up, its the second oxygen sensor counting from the left, with the red wire.. it's oxygen sensor 2 on cylinder bank 2, and it plugs into the pipe below the exhaust manifold that's facing the front of the car.. now i have another question.. the sensor from the nissan dealer costs about $150... if i get it from auto zone it costs about $90... on the website it says its a Bosch OE type oxygen sensor.. is it ok to use that instead of the factory one? because money is kind of tight right now
Old Dec 12, 2006 | 02:16 PM
wyche89's Avatar
holy crap, do we have to have the ecm reprogrammed after we change the 02 sensor?
Old Dec 12, 2006 | 02:21 PM
RLW001's Avatar
Get the OEM, but tell them they are asking list plus. My dealer quoted $147 for 1 sensor and when told them I can get them for $108 he matched the price.
bbsitum
Sep 6, 2019 07:31 PM
220k+ A32
Sep 11, 2015 02:18 AM
dcardello
Sep 3, 2015 11:44 PM
