HELP!! Car Barely Moves!!!!
Old Jan 2, 2007 | 08:18 PM
bigballa97
sup guys, so basically my cousin dropped off his 00 maxima to replace the tranny (used 35k miles), and took it out for a spin. Theres another problem, the car doesnt want to move. In other words, ill press the gas pedal or floor it, and it'll only raise up to 2k rpm and start going back down, but once you start leaving the gas the rpm starts rising. Changed the TPS, checked/changed feul pump, removed CAT. opened up the airbox from throttle body. we sprayed carb. cleaner through the airbox n it revs fine, but after that its back to the same thing. Were stumped!!! i will change the MAF sensor, and all coil packs, let me know what else it could be!!!
EDIT: before and after reving, car has alot of vibration
Old Jan 2, 2007 | 08:45 PM
zero2sixtyZ's Avatar
You embarrass me.
sounds like a MAF. if you disconnect the connector, will it go limp mode and do the same thing?
Old Jan 2, 2007 | 08:50 PM
OC guy's Avatar
2002 maxima se
its maf but you can also change coils, plugs and replace the pcv valve while you are at it.
edit: it could also be iacv.
Old Jan 3, 2007 | 12:14 PM
mist max2000's Avatar
sounds like possible MAF.. ive had those symptoms b4 and that fixed it,.. do the maf asap and see whats up,.. 100 bucks tops and takes like 20 mins for install
also,.. not sure if u know this or not so i might as well say it,.. MAF will effect the tranny in these cars like crazy,.. like to the point that you could replace the MAF and then tell him you put a new tranny in it and he wouldnt know the difference haha .. g/l
Old Jan 3, 2007 | 12:28 PM
MaximaGT-R's Avatar
I'm a Happy Man!
sound like the maf but my friend who had a similar problem a while back and all that was changed was the coils. good luck with this though
Old Jan 3, 2007 | 01:45 PM
madisonmxma's Avatar
Unplug the MAF sensor plug and start the car and it should be in limp mode. The car should run better than it does now if it is the problem.
Old Jan 3, 2007 | 04:20 PM
bigballa97
i changed his MAF, and its running perfect. everything else was fine too (pcv, coils)
Old Jan 3, 2007 | 04:22 PM
bigballa97
i would never do that, so yea basically when he had purchased his car, the tranny was slipping from 2nd-3rd, but the problems he has now was after we replaced the tranny. but after swapping the MAF, its running perfect.
Old Jan 3, 2007 | 08:52 PM
haha i know i was only kidding,.. but thats good to hear the max is runnin strong,...
i wonder how many people in general have replaced trannys when all they needed was a MAF .... hmm
Lakersallday24
Jun 16, 2019 01:35 AM
Stagnet04
Aug 16, 2015 11:15 PM
BobMax
Aug 15, 2015 12:35 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
