Lowered and Alignment Problem:
Old May 8, 2008 | 09:24 AM
  #41
hotstartup's Avatar
doesnt look like the alignment did much besides changing the toe. adjusting toe takes them 5 mins to do. the caster specs are within range at 2.6 wy, it can be a little different and still be ok
Old May 8, 2008 | 05:11 PM
  #42
DoonBusy's Avatar
I actually had a similar problem....my steering wheel was not centered causing the car to always pull right even though I had it aligned. so i took it back to the place i purchased my tires from and they fixed it
Old May 9, 2008 | 12:20 AM
  #43
CMax03's Avatar
Hey I found that when initially getting my alignment done at Firestone the jerk that was doing it...didn't remove the engine and trans splash shields cause they are blocking the two front transmitters light beam thus giving you a erroneous reading! I took the car to another Firestone further north, and the tech there during setup noticed the splash shields hanging between the 2 front transmitters so I removed them! Eveything was well with in spec's, No camber bolts needed just a small toe adjustment. I'm running Illuminas and Progress Performance Sport Springs, 18" rims with 245/40/18 Nitto 555's! Runs straight and smooth going on 1 yr since I lowered it 1.75" F and 1.5 R.....
Old Jun 6, 2008 | 06:40 PM
  #44
niagara22's Avatar
Where did you get those headlight for your Maxima?
Old Apr 13, 2009 | 08:15 PM
  #45
DrOmed's Avatar
Took it to Sears and now its alll screwed up!
Originally Posted by EastSideMaxima
I had this issue..
I was at Sears getting tires installed and had them Align it...
They came back and said the Camber was off and needed more time to get it right.... I said "Sure.. whatever..." they took care of it and I'm good ever since...
I'm getting this bump steer/castor problem/ wondering steering ever since I had the alignment done. Anyone have a suggestion for this?
Old Apr 19, 2009 | 05:10 PM
  #46
Ahmad_1290's Avatar
Did you try rotating? You could have radial pull.
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
