does anyone have these fog lights?
Old Jan 10, 2007 | 07:01 PM
absoundlab
im looking to get different fog lights and I dont know if I want yellow fog light or clear smoked fog lights or smoked fog lights?
my car is sterling mist and I have 2003 headlight on there with black eye lids and the headlights have ae mod done to them and soon to be stillen lip kit all the way around.
do any of these ebay fog lights have good light output?
what do you guys think?
clear smoked
smoked
yellow
Old Jan 10, 2007 | 07:16 PM
OC guy's Avatar
2002 maxima se
none of that will fit on your car without the rewiring etc. i was also looking to buy those yellow ones but when i figured that they are not worth the time and money. I just bought yellow lamin-x tint tape for my fogs and now my fogs looks better than those ebay ones. and produce the pure yellow output with yellow POLARG H3 bulbs in them.
Old Jan 10, 2007 | 07:30 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
The wiring is the same as any other aftermarket fog light set up. Worth the time IMO. It will fit your housing perfectly since it's made for your car. As far as light output you'll more then likely have to upgrade your bulb.
Old Jan 10, 2007 | 07:38 PM
OC guy's Avatar
2002 maxima se
ya but its not a plug and play product.
why would anyone cut the stock connector etc. just to fit these cheapo fogs. stock ones are better. well to each his own so no comment!
Old Jan 10, 2007 | 07:44 PM
Orgullo's Avatar
There is no need to cut the stock wiring.
Just run your ground... your power and you can splice into the same wiring that you would do the parking lot and fog light wiring set up.
Tape off the ends of your stock wiring just in case you do decide to go back to stock. The 00 / 01 fog lights are not any better then these.
If there is any questions on how to run this type of set up or to run your light to a switch then pm me.
Old Jan 10, 2007 | 07:55 PM
OC guy's Avatar
2002 maxima se
wow i didnt know that. so would the switch remain stock or do we have to place new switch for those lights? the reason i was avoiding those fogs because i thought they are quite hard to install. but you cleared pretty much out so i might consider buying a set in future. thanks.
Old Jan 10, 2007 | 08:02 PM
Orgullo's Avatar
You can run the set up through your parking lights which is the easiest.
Splice your fog light wiring together. Pos to Pos and Neg to Neg. Take your headlight (either side) out and cut the tape from around your parking lights to expose the wiring. Determine your Neg and Pos and splice your fog light wiring into your parking light wiring. Run a separate piece of wiring from your Neg side of your parking lights to the Chasis. This will blow fuses for you as oppose to your parking lights.
I put aftermarket fogs on my car and have ran this set up for almost a year with NO problems.
Old Jan 11, 2007 | 02:36 AM
SoonerFan's Avatar
Cletus
wow..."JDM yellow"
yellow - not JDM
yellow fogs - not JDM
anything for a maxima - not JDM
most overused word in after market car product advertising
Old Jan 11, 2007 | 05:49 AM
MaximaGT-R's Avatar
I'm a Happy Man!
a friend of mines is got the black diamond one they look sweet but i dont really like the light out put on it.
Old Jan 11, 2007 | 10:49 AM
AceofSpds's Avatar
wat
Originally Posted by soonerfan
wow..."JDM yellow"
yellow - not JDM
haha he could try and put I-30 fogs those are kinda jdm
Old Jan 11, 2007 | 09:31 PM
pinakbet's Avatar
I have the yellow fogs you posted above.
I previously had the lamin-x, which eventually dried out, charred and left a brown spot.
The install was VERY simple. No splicing.
If you notice from the pictures, the harness/wire seem different.
What i ended up doing was reuse the OEM back cover(the thing u twist and pull) and swap it with the new one.
A ground screw is all that holds the back cover on the fog.
Take a look at the little shields in your fogs though. They may not be centered. It may affect your beam pattern.
Old Jan 12, 2007 | 12:19 PM
XyNoix-HIC's Avatar
WHACk....lexus capsules FTW
Old Mar 16, 2007 | 05:44 AM
maximo-SE's Avatar
my laminx sucked so bad..... need to get lexus capsules, anyone remember where they bought it? thanks
Old Mar 16, 2007 | 07:29 AM
ionblu_max96blk's Avatar
Hey There Mr. Paperboy...
i'd like to know where to get the capsules as well^^
Old Mar 16, 2007 | 08:10 AM
gaby617's Avatar
i actually ordered the smoked ones, expecting them early next week. i was abit iffy until i seen them on another max. i upgraded fog/headlights to piaa extreme white plus so hopefully itll look much better than the stocks.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
