pulley damages oil pump?
Old Jul 6, 2001 | 07:04 AM
QUANSUNG
whats the factory spec torque setting for the underdrive pulley bolt? my oil pump went causing engine damage broken cams,timing belt and bent valves ,nissan says the pulley was over tightend and caused the problem,the torque spec the gave me was 29/36tq.
Old Jul 6, 2001 | 07:27 AM
My 4DSC
i thought your engine broke because you shifted into 2nd gear on accident at like 80mph or something?
Old Jul 6, 2001 | 07:40 AM
QUANSUNG
thats what i thought,they said somthing broke in the oil pump causing the other components to brake down,they said the pump is right behind the pulley bolt.
Old Jul 6, 2001 | 08:04 AM
UMD_MaxSE's Avatar
Got Bent?
hmmm.....can the oil pump fail because of the pulley bolt?
Old Jul 6, 2001 | 08:52 AM
theMax's Avatar
unorthadox says this is unrelated
but I would see why they would be biased. Seems honduhs had a similar problem. Check out this article on their page....
http://www.unorthodoxracing.com/faq.html
Old Jul 6, 2001 | 09:17 AM
y2kse's Avatar
I suppose we could run a poll to find out, but perhaps it would be just as easy to ask the question here.
Has anyone besides QUANSUNG had an oil pump fail on their Maxima after installing an Unorthodox UDP?
Old Jul 6, 2001 | 09:28 AM
Dave B's Avatar
Not DAVEB the parts guy
They're screwing ya, buddy.
The 29-36 ft/lbs is correct, BUT you then torque the bolt another 60 degrees which means the bolt is torqueing down to 110-120 ft/lbs. The pulley bolt is HUGE and high grade. You don't specify a bolt like that unless you're torqueing it to well over 100 ft/lbs. Simply put, they're yankin' your chain. I get my information from Chiltons. When you installed the pulley, didn't you have a hell of a time getting the bolt loose? 29-36 ft/lbs would come off with little trouble.
Mared cams, bent valves, "kissed" pistons, blown oil pumps, and shattered clutches are all typical failures when you misshift. When you hit 2nd on a missed 2-4 shift at 80mph (I'm assuming you did this), would EASILY exceed 8000rpms which is WELL over spec on the valve springs, crank, pump, cams, tranny, etc. This is your problem...NOT the UDP.
Dave
Old Jul 6, 2001 | 02:55 PM
2kseman's Avatar
feel a little bit better.............
Dave
after reading your post.....I ended up in a garage to have the nut removed because I cracked my socket "trying" to remove it (crank nut). Anyhow, the mechaninc tightened the bolt with the impact wrench, but it wasn't torqued. Should I be concerned about the overtighten of that crank nut with the impact gun?
Old Jul 7, 2001 | 10:45 AM
got rice?'s Avatar
Miatas have had several oil pump failures due to the pulley upgrade, too. THis does not seem to be a problem on Nissans, though.
Old Jul 7, 2001 | 12:19 PM
My 4DSC
Hey Dennis
Maybe you should take your car back from the dealer and put the stock pulley on...then bring it to another dealer...
Old Jul 7, 2001 | 03:23 PM
Maximam's Avatar
Dave
I agree with Dave B on this one.
Mark
BkGreen97
Apr 2, 2016 05:47 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
rbarnes
Dec 31, 2015 06:29 PM
RWCreative
Sep 21, 2015 11:01 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
