6-speed swap (people who care only)
Old Feb 18, 2007 | 03:18 AM
Hoooper
This thread is for people who care about the swap only, if you want to talk about Mathell PM me please. this is information, not a law discussion
Parts needed:
1) manual ECU
2) manual axles (both)
3) 6Speed trans
4) shifter assembly
5) clutch pedal assembly
6) brake pedal assembly
7) clutch master cylinder
8) clutch hydraulic lines
9) clutch slave cylinder
10) anti-lock brake unit mount
11) shifter cables
12) shift mount, ****, bushings etc
13) manual wiring harness(could be optional, not sure)
14) transmission mount
15) shift boot assembly
16) manual starter
The swap I guess was mostly like a 5-speed swap, I didn’t do it myself so I can give step by step instructions, but I can say some quirky things that need to be done.
1) Trans mount must be CUT off the frame, then the manual trans mount must be either welded or bolted on in its place.
2) Old shifter cable may have to be cut to be removed.
3) Neutral safety switch must be jumped in order for the car to start, place a fuse or a jumper or item of your preference where needed in the place of the NSS relay.
4) Immobilizer unit must be reprogrammed for the new computer
5) New starter must be installed because the auto one is not correct
6) Wiring harness may or may not be needed, I got a new one and mine runs now, so…
7) My flywheel was damaged and caused a lot of headaches, so make sure you have a working flywheel
__________________
Old Feb 18, 2007 | 05:22 AM
Gle03Max's Avatar
I am very interested in this. I plan on doing it myself, but out of curiousity, do you mind if I ask how much you payed for parts and labor.
Old Feb 18, 2007 | 05:51 AM
Kevlo911's Avatar
Kevlo for President
Isn't the tranny mount already bolted to the frame? Why do you have to cut it off?
Old Feb 18, 2007 | 02:24 PM
Hoooper
you have to cut the AT one off because it is different from the MT one.
GLE03, it was 6-7k, but thats with 5.6 times the labor cost than i signed on. you should be able to get 1000 labor.
make sure you look at the flywheel, i didnt see anything first and neither did my mechanic. but when i got it back i looked and saw a really obvious problem.
Old Mar 17, 2007 | 12:03 PM
BIGMAX19's Avatar
Hey wassup!!! whats the anti-lock brake unit mount?
Old Mar 17, 2007 | 01:38 PM
OutMaxxed's Avatar
good god 6-7k?! ..glad you got everything to work
Old Mar 18, 2007 | 09:42 PM
kbjy11's Avatar
^ good god x 2
i'm going to state the obvious... you would been much better off selling your car and buying a manual maxima..
unless the auto took a crap and needed replacing.. but even then the above would probably still apply...
but hey, its your money.. enjoy the freedom
Old Mar 18, 2007 | 09:45 PM
MAXSE5SPD's Avatar
add to the list, the cover that goes above the heatshield that protects the bit of shifter assembly that sits below the floor.
Old Mar 19, 2007 | 09:01 AM
Snolife's Avatar
What we have here is a failure to communicate
Ouch on $$. I will be hopefully be doing this at the end of the year, thank god I know people. I am not paying that much, good god. If thats the case, screw it. Who did the work for you?
Old Mar 19, 2007 | 09:15 AM
LA02MAX's Avatar
People, his car had been out of commission for the swap for several months. This is becuase there were a few nearly un-noticable problems (as laid out in the first post) that they could not get past. That is why it cost him so much money. Have fun hooper with the swap. Your car ran a 14.3 as an auto right? It should be much quicker now!
Old Mar 19, 2007 | 09:19 AM
BIGMAX19's Avatar
On hoooper's profile he states that his car has been converted to 6th speed... Has anyone spoke to him?
Old Mar 19, 2007 | 09:22 AM
LA02MAX's Avatar
um....you're in his thread....
Old Mar 19, 2007 | 09:28 AM
BIGMAX19's Avatar
I know.. but he has been banned so it would be nice to have it confirmed that his swap was successful...
Old Mar 19, 2007 | 09:38 AM
LA02MAX's Avatar
Yes he is finished. He is pointing out some difficult things he went through along the way.
http://forums.maxima.org/search.php?searchid=555355
Old Mar 19, 2007 | 09:39 AM
MAXSE5SPD's Avatar
link doesnt work
Old Mar 19, 2007 | 09:41 AM
LA02MAX's Avatar
then search his posts yourself. Click on his name and "Find more posts by Hooper". He's posted several things about his 6-speed swap.
Old Mar 19, 2007 | 10:43 AM
steven88's Avatar
Need A Light?
snolife going to manual??
Old Mar 19, 2007 | 10:11 PM
MaxBoost925's Avatar
Drug Money
So Hooper, when are we about to hit up Infineon?
Old Mar 20, 2007 | 11:51 AM
NmexMAX's Avatar
dot dot dot ...
Whenver he's not banned ...
Never mind Perma
Old Mar 20, 2007 | 03:16 PM
steven88's Avatar
Need A Light?
Never mind Perma
i don't see him under ban log?
Old Mar 20, 2007 | 04:28 PM
NmexMAX's Avatar
dot dot dot ...
You're not looking hard enough.
Old Mar 20, 2007 | 04:38 PM
steven88's Avatar
Need A Light?
post the link
Old Feb 17, 2015 | 07:56 AM
Cobrastroker's Avatar
Swapping 2003 3.5 max from auto to 6 speed
Hey guys I want to build my max with a turbo setup soon and I got the 4 speed auto is there anyone who can or would be interested in doing the swap? How much am I looking at in parts minus the tranny(6 speed) and aside from that who's the man I need to see to do the job and waya charge? Please respond asap
Old Feb 18, 2015 | 10:26 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Cobrastroker
Please respond asap
Old Feb 18, 2015 | 10:32 AM
Fakie J Farkerton's Avatar
1 post wonder.
Old Feb 18, 2015 | 10:44 AM
NmexMAX's Avatar
dot dot dot ...
This might help ... maybe.
https://maxima.org/forums/5th-genera...ne-4-days.html
ateick
76
Jun 16, 2019 05:41 AM
Reality sucks
Dec 5, 2017 04:24 PM
AllBlackMax
Aug 30, 2007 06:18 PM
