making a plug and play eu ecu harness?
Old Mar 8, 2007 | 05:27 PM
ColdSHO's Avatar
if all goes as planned my eu should be on its way to me shortly, ive done ,imo quite a bit of research and discovered that greddy makes plug and play harnesses for many a cars, sadly i havent found one for our cars, i figured as much
im a lil worried about tapping into my harness so i was thinking of making my own plug and play harness, i have access to junkyards with several maximas, mainly 4th gens that i could salvage from. i was just wondering what year/s maximas would have compatable harness parts with a 00 5spd fed spec w factory 17s.
granted the wires dont have to line up or anything just as long as the plastic harness fits, i can read a wiring diagram and plan on using my own wire to mate the two parts together.
i figure i can cut the harness for one end and gut the ecu for the other end, then leapfrog the two parts and wire accordingly
it hink that makes sence. any insight or thoughts would be awesome.
thanks all!
Old Mar 8, 2007 | 10:34 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Here is a member who is doing the exact thing.
http://forums.maxima.org/showthread.php?t=512836
Also since u have access to several maximas, I am looking for a ecu so I can have all the parts to make a harness. Is there a way to hook me up too? Let me know.
Old Mar 9, 2007 | 02:20 AM
Puppetmaster's Avatar
I'm making one right now... at least I'm starting to. Its easier to get a wire harness with about a foot or two of wiring, that way you already have one end "done" and for the other end, which is more tricky, you need to find an ECM and hack it up for the end with the pins.
You can use any 00-03 ECM, but make sure it has all the pins you need.
Partial discussion of this in my WTB thread:
http://forums.maxima.org/showthread.php?t=483427
Old Mar 9, 2007 | 07:40 AM
lake3031's Avatar
Question..little off topic of ECM tho
Does anyone know the colors for the OverDrive lead wires that connect to the original automatic shift **** (2001 max SE AE auto)? Replacing **** with the Levoc **** w/ overdrive button, and the person before had a **** with no over-drive button. Dash is apart, and I see no loose wires....I know they have no polarity, but i need to know what colors they are so i can possible splice into them. Thanks ALL
Old Mar 9, 2007 | 08:06 AM
Kevlo911's Avatar
Kevlo for President
Icey2k1 did it on his already.
Old Mar 11, 2007 | 09:44 PM
2k1maxgle's Avatar
Mine wires were white and black. Be careful, those are in there very tight, NO slack what so ever. You can get to them from the driver side of the shifter assembly where all the wires sort of meet and go into that relay and all.
melteye
May 16, 2016 12:02 AM
schmellyfart
Sep 25, 2015 04:47 PM
A32goldylocks
Sep 2, 2015 06:39 AM
BobMax
Aug 19, 2015 04:39 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
