clutch fluid?
Old Mar 25, 2007 | 03:42 PM
jkmay01's Avatar
Lil 8
clutch fluid?
Sorry if this has been posted before? have tried looking thru old threads. Wanted to make sure of the type of clutch fluid that should be used? Still Dot 3 brake fluid? Needed ti add some fluid to clutch resevoir needed to makes sure thanks!!!
Old Mar 25, 2007 | 03:49 PM
young1976's Avatar
yes, same, DOT3 brake fluid, you can even get "Clutch Fluid" which is the same thing from Pep Boys if you want.
Old Mar 25, 2007 | 03:56 PM
jkmay01's Avatar
Lil 8
ok thanks again
Old Mar 25, 2007 | 03:58 PM
SoonerFan's Avatar
Cletus
as stated in your owners manual (and on the clutch reservoir cap) - DOT 3 Brake Fluid
Old Mar 25, 2007 | 05:12 PM
Zero Deuce SE's Avatar
DOT 3 brake fluid just like the brake master cylinder.
Old Mar 25, 2007 | 09:41 PM
jkmay01's Avatar
Lil 8
sorry i bought mine used no manuel i did look on my resovoir cap just said brake fluid ? So we are saying dot 2 or 3? what is the difference? thanks
Old Mar 26, 2007 | 01:32 AM
02nismaxlegnd94's Avatar
dot 3 supercedes 2, its the upgraded formula. dont waste you time looking for dot 2, i dont think it still exists.
Old Mar 26, 2007 | 02:38 AM
I can't remember when I last saw DOT 2 brake fluid. If you go to Wallyworld you will find some Prestone synthetic DOT 3 brake fluid and it will work perfectly. You should be able to download a owner's manual from the Nissan publications website.
Old Mar 26, 2007 | 02:44 AM
http://www.nissantechinfo.com/nissan...p?dept%5Fid=37
Old Mar 26, 2007 | 04:10 AM
Nismo Scorpion's Avatar
DOT 3 all the way around!!!
Old Mar 26, 2007 | 10:57 AM
jkmay01's Avatar
Lil 8
thanks all!!! used the DOT 3 brake all good now
Old Nov 3, 2011 | 07:19 AM
Draco_95's Avatar
Hydraulic mix up
i used Hydraulic they r telling me i gotta replace master and slave question is do i have to replace anything else
Old Nov 4, 2011 | 06:12 AM
young1976's Avatar
What did you use? Oil based hydraulic oil? Need to replace the rubber lines.. can only get those from dealer. or if it hasn't been too long, flush completely all the lines, indluding all the convoluted metal lines that run all over the place on these cars...
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
Need help
23
Oct 2, 2015 08:56 AM
carlosvq30
Sep 26, 2015 09:44 AM
