Any tips before I install?
Old May 10, 2007 | 05:36 AM
ManUtd18's Avatar
I just bought Eibach+Illuminas from a member off the org. They should be at my house when I get home from work and I plan on starting installation as soon as I get home.
I never done anything with springs/struts, but I have been doing A LOT of reading. I have been reading everything I could find.
But I want to know some tips or problems people ran into when installing them.
Any tips will help,
Old May 10, 2007 | 05:45 AM
MyBlue02's Avatar
if its your daily driver and you need the car tommorow, wait till hte weekend or when you have alot of time incase somthing goes arye.
Old May 10, 2007 | 05:53 AM
ManUtd18's Avatar
Whys that? I read that usually the install should take around 5-6 hours. See I want to get them on before Saturday, because that is when I have prom.
I want me Max to look good.
Old May 10, 2007 | 06:11 AM
AcidJake75's Avatar
its 5-6 hour job if you have the right tools. more than likely you will need to get moms and pops to take you to the autoparts store.
Prom?
man I feel old...
Old May 10, 2007 | 06:38 AM
aftd930's Avatar
I put on my s tech and illuminas shocks on with not much problems. I just rented a spring compresor which when you return it you get all your money back. And just followed a step by step write up. and when compressing the springs always point it away from you. Good luck
Old May 10, 2007 | 06:40 AM
upstatemax's Avatar
The biggest thing is to have a breaker bar for the lower bolts that hold on the struts... If you don't have a breaker bar/useable pipe, don't even bother trying.
Ohh yeah, and the spring compressor like said right above me... I forgot it since I have coilovers
Old May 10, 2007 | 06:42 AM
aftd930's Avatar
Actually I think I used this how to: http://www.innerbean.com/housecor/strut_install.html
Old May 10, 2007 | 06:49 AM
aftd930's Avatar
Yes I take for granted my buddy, he has a nice collection of tools. He has the 350zTT in the picture below. I def used a breaker bar to loosen and I believe a torque wrench to tighten back.
If you run into any problems you can always write me a PM and I'll try to get back to you as soon as I can.
Old May 10, 2007 | 06:55 AM
ManUtd18's Avatar
I already got the spring compressor from Advance Auto Parts yesterday.
Also what does a breaker bar look like?
I read this site several times to make sure I have a good idea what I am doing. But I guess I never saw the breaker bar on the list.
Where could I get a breaker bar? and after doing some research, what size breaker bar should I get?
Old May 10, 2007 | 07:11 AM
upstatemax's Avatar
The easy way... Slide a pipe over your wrench and just like magic... You have a breaker bar. No auto parts store around me had one...
Old May 10, 2007 | 07:13 AM
ManUtd18's Avatar
what does a breaker bar do? What kind of pipe do I slide over a wrench?
Old May 10, 2007 | 07:21 AM
4MySwee's Avatar
It's a lever more or less. Gives you an advantage when you need to break a bolt loose. What you do is slide a pipe with a larger diameter then the wrench/ratchet handle, and it acts as an extender for your ratchet.
Similar to what a pulley does for hoisting. It gives you a bit more advantage.
Old May 10, 2007 | 07:24 AM
ManUtd18's Avatar
Alright sounds good.
I'll look into it some more.
Old May 10, 2007 | 07:31 AM
upstatemax's Avatar
You might want to skip the prom and catch up on your science homework... From 9th grade
TDotMax's Avatar
I suggest replacing your dust boots also as they are more then likely ripped. You also would have to trim them.
Old May 10, 2007 | 07:41 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Find someone local who has done this work and get their assistance would be my suggestion. The first time around always takes the longest. Last time I changed out my suspension, I had it done in about 2 hours.
Old May 10, 2007 | 08:41 AM
illlojik's Avatar
I C U
front and back?? by yourself?
Old May 10, 2007 | 09:18 AM
aftd930's Avatar
Looks like this
Old May 10, 2007 | 09:20 AM
aftd930's Avatar
Have a impact wrench?
Old May 10, 2007 | 09:29 AM
opanick's Avatar
luckily my uncle has a shop and this bad boy made spring compressing a breeze when I did my drop
Old May 10, 2007 | 09:31 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Yes, both front and back.
Yup...electric impact wrench FTW!
Old May 10, 2007 | 03:04 PM
RLW001's Avatar
Don't forget PB Blaster to help remove rusted bolts.
Old May 10, 2007 | 05:40 PM
reeloop's Avatar
5 hours with the right tools? i think not? perhaps if its your first time.
My friend did the front in less than 40 minutes, the back was twice as long because he had to remove a metal plate that is behind your back seats to get access to the strut bolts.
so total time was 2 hours, and that included many smoke breaks, eating food, and talking about bikes. heh
oh yeah, he had air tools :-)
Old May 10, 2007 | 06:13 PM
Squirrel82's Avatar
No need to take off the plate to get to the nuts.
Old May 10, 2007 | 06:42 PM
ManUtd18's Avatar
Well I was able to get the front 2 in. I started later than I wanted to.
But I did take it for a spin a noticed a HUGE difference in the way the car drives.
I'll let you know how it drives when I have all 4 of them on.
Old May 10, 2007 | 07:13 PM
punjabi's Avatar
make sure that one of the upper strut mount bolt lines up w/ the rear strut mount when you do the rear u ll know what am saying just take a gud luk at the rear strut assemble when u take it of otherwise u might run into a problem where the lower strut mount wont line up
Old May 10, 2007 | 07:53 PM
ManUtd18's Avatar
Alright, Ill make sure to take a good long look at it.
MaxLife17
Jun 27, 2019 01:37 PM
dcam0326
Sep 18, 2015 04:52 PM
2kmaximel
Sep 16, 2015 03:19 PM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
