Header installed now there are noises
Old May 15, 2007 | 04:57 AM
03MAXTNR's Avatar
Well i just installed the headers and i really like them except that there is alot of noise when i put my automatic in reverse. Theres alot of deep tone followed by shaking. It only does it when in reverse. I cant quite figure out where the noise is coming from. Hopefully this is an easy fix.
Old May 15, 2007 | 05:09 AM
upstatemax's Avatar
Make sure everything is tight... Double check your Motor Mounts.
Old May 15, 2007 | 06:48 AM
03MAXTNR's Avatar
is this noise something i should be really concerned about? has anyone had similar problems like this?
Old May 15, 2007 | 06:52 AM
ManUtd18's Avatar
Did you try searching it?
http://search.yahoo.com/web/advanced...r=fp-tab-web-t
Old May 15, 2007 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
Do you have a strut bar? The engine is in a reverse load situation, so it moves toward the front of the car when in reverse, vs when the car is in a forward gear.
If you're 4AT (automatic) one way to try and see what's happening (i.e. rubbing on something) is to engage the eBrake, put in reverse, and check under the hood to see what might be visibly noticeable.
Old May 15, 2007 | 09:32 AM
03MAXTNR's Avatar
ill give that a try. is there anything i should look at in particular. has anyone had this problem before?
Old May 15, 2007 | 10:21 AM
Black026spdLSD's Avatar
my buddy has a strut bar in his 99 Acura tl and he has headers and also has the same problem/noise, its not a problem hese had it for over a year now.
Old May 15, 2007 | 10:45 AM
NmexMAX's Avatar
dot dot dot ...
Invalid comparison, different car. For us there are remedies. I.e, washers for said strut bar. But the OP needs to verify this is in fact his problem. As well as provide information, such as tranny type, strut bar brand etc. Since most if not all of us w/ headers did not experience this. But, until we know the current unknowns we can't draw any valid backed conclusion.
Old May 15, 2007 | 11:49 AM
03MAXTNR's Avatar
the only mods i have are intake and headers. No aftermarket strutbar. As stated before i have an automatic transmission. Im going to put the car in reverse and have my friend see if the headers are touching anything.
Old May 15, 2007 | 07:05 PM
03MAXTNR's Avatar
i just checked to see where the noise was coming from and it looks like there is a piece of metal like a fire wall that is touching the rear headers so im going to see if i can bend it a bit.
Old May 16, 2007 | 09:09 AM
03MAXTNR's Avatar
Did anyone take it off when installing there headers.
Old May 16, 2007 | 01:38 PM
NmexMAX's Avatar
dot dot dot ...
You have to be more specific, at least a picture.
But I didn't take anything off. I do have first gen headers though.
Old May 16, 2007 | 02:07 PM
MaxBoost925's Avatar
Drug Money
10 char
Old May 16, 2007 | 04:24 PM
upstatemax's Avatar
He is talking about the Rear exhaust manifold heat shield that is bolted to the firewall...
To the OP- I don't think anyone removed it, they just bend them back. Not all will rub/vibrate... It seems to be the luck of the draw.
Old May 16, 2007 | 05:37 PM
NmexMAX's Avatar
dot dot dot ...
I tossed my heat shields, that's why I was
Old May 17, 2007 | 09:17 AM
03MAXTNR's Avatar
the problem i had was the rear manifold black heat shield. it was touching the headers so i just got rid if it. When the car was in reverse it would touch it creating a vibration and loud noise. Now its gone.
Old May 17, 2007 | 09:39 AM
ManUtd18's Avatar
Cool, I'll remember that when I get headers.
MaxLife17
Jun 27, 2019 01:37 PM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
