Engine Starts then stops....low idle RPM??
Old Jun 19, 2017 | 03:00 PM
  #121
Tone51510's Avatar
Same issue... Please help
Originally Posted by joebangaa
Just recently my car would die immediately after startup. Either that, or the RPMs will drop so low that it seems like the engine had died, followed by a quick rise in RPMs back to a normal idle. I'd been suspecting the IAC valve for quite some time now but am confused about the situation since IAC valves usually have trouble bringing up the RPMs to normal idle range when the car is cold. My problem usually occurs when I start up the engine shortly after I had shut it off (like after I'd made a very short trip).
Hello hope all is well. I am having the same issue as you once had and was wondering how you fixed this issue. Any help would be greatly appreciated. Thanks for your time.
Old Jun 19, 2017 | 03:10 PM
  #122
bnewall1's Avatar
Greetings!
Please see my posts on Page 3. My problem was fixed by replacing the MAF sensor. I thought it was an IACV problem, but it was just the MAF.
Old Jun 19, 2017 | 03:51 PM
  #123
Tone51510's Avatar
Originally Posted by bnewall1
Greetings!
Thank you for the fast response. Hopefully this is the answer to my problem.
Old Jun 19, 2017 | 08:15 PM
  #124
cornholio's Avatar
It would help us to know the year of your car also. 02-03 have no iacv so that would be easy to rule out
Old Jun 20, 2017 | 04:56 AM
  #125
Tone51510's Avatar
03 Nissan Maxima se
Old Jun 20, 2017 | 10:15 AM
  #126
maximatech12's Avatar
If your concerned it's an MAF you could hook up and pull the Grams/second in real time.
Could this tell if it's bad?
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
doobadoo
Aug 15, 2015 06:43 PM
