GM Top engine cleaner
Old 05-25-2007, 02:45 PM
5thgenmaxima's Avatar
Just curious if any of you 3.5 guys have tried this for to fix your oil consumption issue?
It's basically a solvent you pour into your spark plug holes, clean out the carbon/other gunk, then pour in more top engine cleaner and let it sit over night.... When cranking the engine after letting it sit I've seen huge chunks of carbon come out... Since the stuff sits in your combustion chamber, I'm sure some of it works itself past the oil ring and cleans that crap out too...
I've seen alot of oil burning engines become cured from this process, if only for a few months, it still seems to work really well.. The important part is to change the oil after your done before driving 200 miles.
5thgenmaxima is offline
Old 05-25-2007, 03:17 PM
Cletus
SoonerFan's Avatar
oil consumption is caused by bad rings....not carbon or gunk
SoonerFan is offline
Old 05-25-2007, 04:53 PM
We use it all the time on engines that have excessive blow-by. If the oil ring is just gunked up from small deposits and not able to scrap the oil from the cylinder walls the oil cleaner will help clear up those passages....Maybe the cylinders just to glazed over and that's the problem. I don't know just figured if no one had tried it that it was worth a shot.....Cheap fix.
Old 05-25-2007, 05:31 PM
Cletus
SoonerFan's Avatar
it doesnt work...it has been tried.
derekinthez
11-13-2022 04:00 PM
captchaos
03-15-2016 12:18 PM
fastcarny
10-06-2015 10:42 AM
seesole
09-14-2015 12:38 PM
ballerchris510
09-11-2015 05:29 PM
Quick Reply: GM Top engine cleaner
