E brake light
Old Jun 5, 2007 | 12:12 PM
Rich96's Avatar
E brake light
My emergency brake light is intermittently staying on while I'm driving.
Does that just mean my e brake needs an adjustment? Is it also a warning light for other brake issues?
Old Jun 5, 2007 | 12:15 PM
NmexMAX's Avatar
dot dot dot ...
It might mean low brake fluid. Check the level.
Old Jun 5, 2007 | 12:24 PM
godlyone's Avatar
ahhh! cliMAX!
is the battery light on too? could be alternator.
NmexMAX's Avatar
dot dot dot ...
Old Jun 5, 2007 | 12:41 PM
Dark-V's Avatar
Could be your pads are low. I had that happen to my old car. Replaced the pads/rotors and everything was good.
Old Jun 5, 2007 | 12:58 PM
Rich96's Avatar
Pads were very recently replaced, rotors resurfaced. The battery light is not on as well, but the car has been getting harder to start and I assume my 4 year old battery is getting ready to die.
The PBR pads I used on the rear suck....making tons of noise...I just got new shims that I've been meaning to install.
I'll check the fluid tonight......
Old Jun 5, 2007 | 02:29 PM
Stardust's Avatar
F---ing Kangaroos
Thats not what it means on the max.
Old Jun 5, 2007 | 02:36 PM
NmexMAX's Avatar
dot dot dot ...
Actually, it's a possiblity. If there is little material left on the pads, the volume of fluid in the brake system must be compensated for, therefore, more fluid must be put into the caliper as a result. And if the fluid wasn't very full to begin with, the fluid drop will cause a brake light.
The sensor can be seen on the master cylinder.
Old Jun 5, 2007 | 03:04 PM
Stardust's Avatar
F---ing Kangaroos
But even with the pads worn all the way down the fluid isn't low enough to trip the light (at least on my car).
Old Jun 5, 2007 | 03:26 PM
NmexMAX's Avatar
dot dot dot ...
2 major points. But I know you knew that.
Old Jun 5, 2007 | 03:44 PM
Stardust's Avatar
F---ing Kangaroos
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
