Trying to pinout 2000 ecu
Old Jun 10, 2007 | 07:15 AM
absoundlab
Alright I know this has been discussed before but there has never been a for sure pinout for a 2000 maxima ecu for a vafc-II
This is a pinout for a 2002 after looking it over I believe its different from a 2000.
This is an exact pinout for a 2000 maxima.
for the vafc-II the wires that need to be used are
green (tach) 23 on ecu
black and brown (ground) 48 on ecu
yellow and white (maf) 61 on ecu
red and red (power) 110 on ecu
gray (throttle signal) is the throttle signal the same at tps? would it be 16 or 91 on the ecu?
blue (o2 sensor) I can't find any o2 sensor wires.
Can you look over this and make sure it looks right and can you please fill me in on the throttle signal and the o2 sensor.
also the purple wire on the vafc-II harness is for the knock sensor. gtr-rider told me I dont need to hook it up is that true for a 2000?
Old Jun 10, 2007 | 01:48 PM
NmexMAX's Avatar
dot dot dot ...
Don't use the o2 sensor wires, it's a waste of time.
Use the FSM for more accurate representation of said TPS sensors.
Old Jun 10, 2007 | 01:53 PM
absoundlab
I dont have a fsm
Old Jun 10, 2007 | 02:11 PM
NmexMAX's Avatar
dot dot dot ...
phatg20, use it
Old Jun 10, 2007 | 02:18 PM
absoundlab
which section in the fsm should i look in?
Old Jun 10, 2007 | 02:20 PM
NmexMAX's Avatar
dot dot dot ...
Ec
Old Jun 10, 2007 | 02:22 PM
absoundlab
what page?
Old Jun 10, 2007 | 02:24 PM
NmexMAX's Avatar
dot dot dot ...
Read it ands see which sensor changes V when the throttle plate is opened.
Old Jun 10, 2007 | 02:26 PM
absoundlab
dude forget that its like 500 pages
Old Jun 10, 2007 | 02:28 PM
NmexMAX's Avatar
dot dot dot ...
Use some of your more common senses and go to the TPS section.
Old Jun 10, 2007 | 02:30 PM
absoundlab
well from what im looking at pin 91 is the tps
Old Jun 10, 2007 | 03:47 PM
upstatemax's Avatar
Thanks for doing a bunch of work for me... I was going to do this if I attempt to install my VAFCII this comming week.
Old Jun 10, 2007 | 03:55 PM
absoundlab
you're welcome but I wish over people on this forum would help out as much as im helping others.
Old Jun 10, 2007 | 08:56 PM
absoundlab
alright NmexMax I figured everything out.
in the fsm its ec - 114 through ec - 121
tachometer green wire on the vafc-II harness : goes to the green wire with the white stripe. this harness is found behind the cluster and it is the harness that goes to the tach gauge
ground black and brown on the vafc-II harness goes to pin 48 on the ecu.
you tap both brown and black onto ground wire 48. brown goes closest to the ecu and black 1 cm away
maf yellow and white on the vafc-II harness goes to pin 61 on the ecu. you have to intercept pin 61 on the cu harness. in other words cut 61 and then the yellow wire from the vafc-II harness goes closer to the ecu and the white wire goes on the other side.
power red and red on the vafc-II harness goes to pin 110 on the ecu. tap both red onto pin 110 1 cm apart
throttle signal is the gray wire on the vafc-II harness goes to pin 91 on the ecu. tap gray wire onto pin 91
and thats it according to streetz lengend you dont need to hook up the knock senor or the o2 sensor
Old Jun 10, 2007 | 09:37 PM
absoundlab
and
tachometer green wire on the vafc-II harness : goes to the green wire with the white stripe. this harness is found behind the cluster and it is the harness that goes to the tach gauge.
Old Jun 11, 2007 | 09:03 AM
Stardust's Avatar
F---ing Kangaroos
Originally Posted by absoundlab
what page?
Quit being lazy and do something yourself
Old Jun 11, 2007 | 09:05 AM
Stardust's Avatar
F---ing Kangaroos
BTW: thats you just complained about having to look something up yourself.
Old Jun 11, 2007 | 09:44 AM
absoundlab
whatever get out of my thread
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
gigabyte
Jan 6, 2017 06:05 PM
Need help
23
Oct 2, 2015 08:56 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
