2000 SE Engine 'Stumbles?'
Old Aug 14, 2007 | 12:11 PM
zoutv's Avatar
I have a 2000 SE
For a moth or two now, when I start the engine of my max, it will stumble a bit on start. In that the engine seems to seize up for 1 ½ seconds; sounding like the pistons cannot move. But sometimes it sounds like 3 or 4 of the pistons are running fine, while 2 of them are stalling. Then, the other pistons start fine and the engine sounds normal.
I know it’s hard to say from the above description, but anyone have an idea what it may be? I had all of my spark plugs replaced in June 06 with NGK Platinum plugs. In May 2007 I had my MAF sensor replaced due to lack of acceleration/performance.. I replaced the MAF as there was a general loss of acceleration about 9 months ago, and it was a bit sluggish. The car seems to have its moments of ‘sluggishness’ all over again. (The whole reason I replaced the maf.)
I wish I could post an audio clip of this, which would be easiest. Anyone have an idea of why it’s ‘stumbling?’
Old Aug 14, 2007 | 02:47 PM
Professor's Avatar
Check your coils/Replace.
Old Aug 14, 2007 | 03:57 PM
808MAX-SPEC's Avatar
The problem you described is exactly what I had. I replaced all six coils and my problem was solved.
Old Aug 14, 2007 | 06:24 PM
zoutv's Avatar
How much would that run me? Parts and Labor if I brought it to a shop...?
What are the other symptoms of bad coils..?
Old Aug 14, 2007 | 11:49 PM
http://forums.maxima.org/showthread.php?t=198517
Old Aug 15, 2007 | 06:04 AM
Professor's Avatar
Call Dave B, there very easy to change yourself , i had mine out yesterday, some look diff then others like they where already replaced, they have silver dots on them too, dunno what thats about.
Old Aug 15, 2007 | 09:33 AM
Kyle00's Avatar
WSH for teh cup
The plugs with the silver dots are updated plugs. So basically, don't buy plugs without the silver dots or else you'll have the same problems again.
Old Aug 15, 2007 | 09:58 AM
KL77's Avatar
I notice there are 2 different part #'s for the coils for my 2000 Maxima SE, anyone know the difference?
Old Aug 17, 2007 | 11:29 AM
J-Rod's Avatar
dont' know difference, but i would hook it up to computer before shelling out money for coils. just to make sure.
Old Aug 17, 2007 | 11:33 AM
zoutv's Avatar
Ok, so it prob the Ignition Coils, anyway....... If it is that, will lower my gas mileage, or impede acceleration? Or is it just at startup is the problem..?
Old Aug 17, 2007 | 11:36 AM
J-Rod's Avatar
on mine it did both -- because it is misfiring
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
RinconI30
Nov 10, 2015 10:55 PM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
