How to replace ball joints
Old Sep 6, 2007 | 10:54 AM
Love_00_Max's Avatar
I got a new set of OEM ball joints and want to replace them. I checked up on the web and a pickle fork is recommended to get the old ones out (though it would destroy them).
Now, can I replace them w/o taking apart the LCA and axle nut? The FSM details removing the axle nut to reduce the tension on the LCA.
Any suggestions is appreciated.
Old Sep 6, 2007 | 11:47 AM
oldngivout's Avatar
Willing to learn
You will have a difficult time removing the nut from the old BJ without first removing the CV axle. It is definitely in the way. Also, you have to figure out how you are going to press out the old one & install the new one with the LCA hanging on the car. C-clamp press will work, but a floor shop press is much better.
Old Sep 6, 2007 | 12:04 PM
Actually the BJ looks like the one below in this URL
http://catalog.drivewire.com/drivewi...on=983398&fm=1
All that is has is a ball joint, cotter pin and a clamp. Wouldn't the old ball joint come off if the castlenut is removed and the clamp removed? Pardon my ignorance, I don't get this deal about pressing the BJ onto the LCA.
Old Sep 6, 2007 | 02:13 PM
oldngivout's Avatar
Willing to learn
You will understand when you begin to disassemble it.
The ball joint presses into the LCA, I don't know what this clamp is that you are referring to.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
