TCM Reprogram vs. Replacement ?
Old Aug 1, 2001 | 01:33 PM
Phydeaux's Avatar
Just talked to my Nissan service dept about working on the automatic in my 2k SE. They say they only do a reprogram of the TCM for TSB 39B repair instead of replacement. Are they cutting corners on this too much or have nayone else had a similar reprogram with favorable results?
Old Aug 1, 2001 | 02:05 PM
Paul6speed's Avatar
No, I think that's reasonable. Are they going to replace the solenoids? I thought that was the first line of action.
Old Aug 1, 2001 | 02:18 PM
Phydeaux's Avatar
They said that there is a test to see if the solenoid is bad i.e. "doesn't meet spec". The dealer service rep sounded like they don't just do a blanket replacement of both parts (according to this service dept at this dealer).
I'm looking to see if anyone else has had similar experience with this repair or if I should be looking for better handling of this TSB at a different dealer service shop; not one that may be cutting corners.
Old Aug 1, 2001 | 11:49 PM
azylstra's Avatar
You cannot reprogram a TCM or an ECU in a 2k model. That capability was not introduced until the 2001 model. There is no test to see if the solenoid is bad. All solenoids with the same part number are exactly the same, therefore they are all bad. Here's the test: you drive, master tech sits in passenger seat, keep driving like a maniac until you get him to acknowledge the slip and agree to order the solenoids, then pull back into the dealer lot. Then you will come back and get the solenoids installed. Then come back again, take him for another ride, and get him to order a TCM. Then come back to get the TCM installed. It's a little game they play to save money. Remember, don't ever leave your car at a dealer for diagnosis of a problem. They won't find it. You have to show it to them.
Old Aug 2, 2001 | 12:16 AM
Menasor's Avatar
Hmmmm, thats true. I agree cause i left my car to have check for slippage and three days later i come beck to find it the same as i left it only with five more miles on it.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
