Thumping Noise from Wheel
Old Oct 24, 2000 | 11:34 AM
Hi. I noticed a thumping noise from right front wheel on a used 2000 GLE I bought. Also had allignment problem at highway speed. Had the wheel checked and the rim was bent, so I had it replaced under warranty. Allignment is ok now, but still get that thumping noise. Same frequency as when you get a clicking sound coming off the wheel when a stone is caught in the tread. But thats not what it is. What can this be???
Old Oct 24, 2000 | 11:42 AM
Mabfnar's Avatar
Any vibration during braking? Warped rotors plague the 2000 Max it seems
Old Oct 24, 2000 | 11:46 AM
No noticable Vibrations, but I do get some funny noises coming off the brake pads when releasing the brakes on take-off. Almost every time I take off after starting the car, I get this crunching noise like I just ran over an aluminum can. There may be a correlation between my braking and that thumping noise coming and going. Have not been keeping track of it that way.
Old Oct 24, 2000 | 12:18 PM
Hrdayz's Avatar
I had a similar problem
On my wifes Acura Legend. Like you describe I had a thumping noise that was traced to a bent rim which I had replaced. I didn't however replace the tire which looked okay. After having the new tire mounted to the wheel and balanced, I still had the thumping. The source of which was a cupped tire which resulted from the damaged rim. A new pair of dunlops set me back on the road without the thumping.
Old Oct 24, 2000 | 12:23 PM
Mabfnar's Avatar
Flat spot on tire...
IT could easily alos be a flat spot on the tire from a hard stop(abs is standard though right) you said it was used right? previous owner could have did a power slide with emergency brake...that would create a flatspot on the tire and then produce a thumping and even possibly make the car feel misaligned..
Just my .02
Old Oct 24, 2000 | 02:12 PM
Originally posted by yo_its_ok
NHTSA SB610991
NTB00030A
Suspension: Independant front attaching mechanism: Strut Rod
Click or Clunk noise from right front strut.
-Peace
Hi yo_its_ok. I don't completely understand your response. Is this an advisory and is there somewher I can get more info on this? Thanks!!!!
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
jfl330
Sep 4, 2015 01:44 PM
