HELP ... My SIGNALS ARE SCREWED !!
Old Sep 11, 2001 | 09:18 PM
Empz's Avatar
Crap ... I installed Windshield washer LEDs about a Month ago and my Car worked Fine.
BUT now ... My Signals flash together!?!??!? Left or Right they BOTH go on!
Can someone tell me why????
Old Sep 11, 2001 | 09:20 PM
Dario's Avatar
Could be the fuse you might want to check it out, i know that happened to me and it was the fuse
Old Sep 11, 2001 | 09:21 PM
Empz's Avatar
I checked the Fuse ... it was Fine.
But just to Confirm ... its the FUSE "inside" the Car, not the Hood right???
Old Sep 11, 2001 | 09:25 PM
Dario's Avatar
yeah its the inside fuse but check this out...its weird but the fuse looked fine to me too but then i tried it again and it worked....my interior lights went out too and then if i remember correctly i disconnected the battery for a little while and put the fuses back in
Old Sep 11, 2001 | 10:03 PM
Empz's Avatar
Aiight ... I'll give it a Try.
Anyone Else have any Suggestions????
Old Sep 11, 2001 | 10:05 PM
Empz's Avatar
BUMP
Old Sep 11, 2001 | 11:22 PM
Empz's Avatar
BUMP
Sorry guys ... I want some more Input!
Old Sep 12, 2001 | 01:18 PM
Empz's Avatar
Re: BUMP
HELP HELP HELP
I tried Disconnecting the Battery ... I tried the FUSE ... Nothing works!
Old Sep 12, 2001 | 09:39 PM
Max_5gen's Avatar
Re: Re: BUMP
HELP HELP HELP
Could you provide some additional info:
1. You tried to switch on/off your hazard switch, didn't you?
2. Any event background - was you changing smth. in the car when it happend or it just did "by itself"?
3. How do lights exactly work - at normal brightness but together (like in hazard mode) or the brightness is significantly less than normal?
4. Do they normally flash when you use remote to open the car?
Mike.
Old Sep 12, 2001 | 09:42 PM
Empz's Avatar
Re: Re: Re: BUMP
1. YEP
2. It happened by Itself. 1 month after the Install.
3. YEP
4. YEP
Mike.
Old Sep 12, 2001 | 09:46 PM
BigDogJonx's Avatar
Re: Re: BUMP
HELP HELP HELP
Wha'd u do? I installed Windshield washer leds also amonth ago and have no problem.
How did you connect the washer leds? to your turn signals or just driving lights? If they were connected to the turn signals, check the wiring, something got shorted or maybe the leds are shorting something out.
Old Sep 12, 2001 | 10:21 PM
Max_5gen's Avatar
Re: Re: Re: Re: BUMP
1. YEP
3. YEP
4. YEP
That's weird - all I can think of looking at electrical diagram is hazard switch which has both lamp wires shortened with each other but it doesn't seem sound for me. When you installed your LEDs - what did you do: just connected them to the ground and battery or connected to some circuit in the car itself? I'd check that installation first because it's quite obvious that you have your left/right turning lamps somewhere shortened to each other. These lamps're connected in parallel to dashboard turning lights and to rear turning lights and to some other elements. So if anywhere in these circuits they got shortened to each other you'd have the described problem. The good news is that it doesn't seem to be too complicated - just lamps, wires, switches and fuses.
Mike.
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
BrandonCause
Sep 14, 2015 10:41 PM
