rubbing?
Old Sep 12, 2001 | 07:01 PM
MaxedOut2g's Avatar
i went to fill my tank today and when i got back home for no reason i juss turned the radio off b4 i pulled into the garage and as i was aligning the car properly, i heard like a hissing type sound as if sumthing was rubbing against each other when i turned the wheels...now, maybe because i have never turned the wheels w/ out the radio on, but i havent noticed it b4....do u guys get it too or is sumthing rubbing cuz i lowered it?
A_T_W
Old Sep 12, 2001 | 09:56 PM
BigDogJonx's Avatar
A_T_W
I had that problem when I lowered my brother's Mazda MX-6. It was because the plate that sits on top of the spring was not fit correctly, so everything i turned the wheel, i heard rubbing and noises.
You might want to check to make sure the Progress springs are sitting correctly on the front struts and the top part of the strut also.
Old Sep 12, 2001 | 10:10 PM
MaxedOut2g's Avatar
aiite thanks man....imma have it checked out whenever i get some time
A_T_W
Old Sep 12, 2001 | 10:49 PM
BigDogJonx's Avatar
A_T_W
Since you have the Progress Springs, I wanted to know, I know they are lower than the H&R, but how is the ride? I want something close to stock. And not too hard cause I really dont want to replace the shocks.
Plus What happens if you pack the car with 5 people, does the back end bottom out? Cause if I pack it now, it almost bottoms out.
Lastly How much?
Old Sep 12, 2001 | 11:12 PM
AznWontonboy's Avatar
i dont know if this has to do with it, but since you dropped your car 2 inches, the camber might be off.. might be negative camber like kevs ride when he slammed his on coilovers. by the way, did you get your car alighned withed the 2 inch drop?
Serotta33
Sep 17, 2015 12:14 PM
thenewguyy
Sep 12, 2015 11:12 AM
MikesChevelle
Aug 7, 2015 05:57 PM
RealityCheck
Aug 5, 2015 06:18 AM
Bucktown
Mar 20, 2001 06:18 PM
