Stereo upgrades for 2000 with Bose
Old Oct 29, 2000 | 05:49 AM
MaxMan
I have the Bose system in my 2000 SE and I am starting to not like it. The "sub" is OK for about 70% of songs but the other 30% abuse it mercilessly (and I have to listen). I had an idea I'd like to run by you guys and see if anyone has done this or thinks it's a good/bad idea.
I was thinking that I would get a Bazooka-type self-amplified subwoofer to install in the trunk and simply cut the speaker wires going to the stock sub and connect them to the speaker-level inputs of the bazooka. Is this a good way to go? Does the sound suffer much from being a speaker-level input (thinking not since it's low freqs only)? Are there line-level outputs on the Bose upgraded system? What have other people done to their Maximas that has worked/not worked?
Old Oct 29, 2000 | 05:23 PM
Groundcntrl
Not Bad
I had that same set up in the 300ZX I used to have I ran the tube line level off the rear speakers. It's about the best you're gonna get without ripping the whole system out. actually you can run an amp(line Level) off the rear speakers and run a normal sub off of it which will sound a hell of a lot better than the bazooka tube. It will be louder thsn the tube and it will hit harder. but if you don't have the money to spend on a decent amp and sub than the tube will do ok. But believe me in 6 months you will be looking for another upgrade. bottom line I would say save for the sub snd amp.
-Groundcontrol
Old Oct 30, 2000 | 05:38 AM
MaxMan
Originally posted by yo_its_ok
I also have the Bose System, supplemented with a 10" non powered bazooka tube, but pushing 200W X 1 Mono JBL Amps.
covers it up nicely. Wish for kick panel speaker like in my friend's BMW, but for now, it does its job by giving the extra punch.
-Peace
Where can you mount said subwoofer and amp? Better question is where did *you* mount them?
Mar 12, 2020 12:06 AM
QueensMAX
Sep 15, 2015 04:14 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
ballerchris510
Sep 11, 2015 05:29 PM
