2000 exhaust
Old Oct 1, 2007 | 09:54 AM
Brad929's Avatar
2000 exhaust
My car sounds like a lawnmower on crack! I have taken off all the lower heat shields and can not find a hole anywhere. I was driving on the interstate when I heard a pop and from then on my exhaust sounded like hell!!!
If anyone knows how to fix this please help!?!? All I know for sure is the sound is between the cat and manifold.
Old Oct 1, 2007 | 10:02 AM
LA02MAX's Avatar
Time for headers
Or if you don't want to go that route, a few good places to start are the gaskets and the y-pipe flex section. If you live where road salt is used, it's entirely possible that the flex section, or even another part of your exhaust is rusted through.
Old Oct 1, 2007 | 10:06 AM
Kyle00's Avatar
WSH for teh cup
How did this guy get away with starting a new thread on his first post?
Puppetmaster's Avatar
Use a piece of paper (or your hand) to try to find where the leak is; just get under there and have someone rev the car while you see if you can locate where the strongest exhaust stream is coming from (other than the tail pipe, obviously).
Donating member.... back on topic please.
Old Oct 1, 2007 | 10:07 AM
Kyle00's Avatar
WSH for teh cup
Originally Posted by Puppetmaster
Donating member....
Missed that.... My falut
Old Oct 1, 2007 | 10:11 AM
Colonel's Avatar
Old Fuddy Duddy
Leave the car outside on a cool night (its getting to be in the 40's around here) and see if you can locate "smoke" under the car.
Be careful when doing the rev method to chock the car so there is no accidental "squishage".
I would also think a little Sea Foam appliation would point out the problem.
Also hand inspect the tops of the pipes. If you are in a salty area, and the salt sits on top might not be obvious.
Old Oct 1, 2007 | 10:14 AM
Brad929's Avatar
I started the car then when i moved the flex pipe the sound changed a little but i didnt feel any pressure. Can the flex be repaired or replaced by itself?
Old Oct 1, 2007 | 10:21 AM
pbn85's Avatar
yea you can buy other flex sections as a replacement..just be sure to buy a LINED flex section as it will keep the noise to a minimum...shouldnt cost too much. I actually have to get a new flex also, my Hotshot one is messed up and Im getting a similiar noise like you
Old Oct 1, 2007 | 10:22 AM
Yeah, many have just replaced the flex by itself. I think most exhaust shops should be well equipped to do that and for cheap.
Old Oct 1, 2007 | 05:34 PM
spdfreak's Avatar
If it's in the flex section, you may want to save a hassle and get an aftermarket y-pipe.
Old Oct 4, 2007 | 04:45 PM
Brad929's Avatar
Thanks everyone for the help. It is the flex pipe. I dont have the $130.00 right now to replace it so would exhaust wrap help the noise for a temporary fix? and would it be worth the extra $230.00 to get a cattman y-pipe?
Old Oct 7, 2007 | 01:14 AM
spdfreak's Avatar
Warpspeed Performance has an aluminized pipe for $200 (IIRC thats including shipping).
Check the for sale section.
Old Oct 7, 2007 | 01:39 AM
The Law's Avatar
I R The Law
If you can get warpspeed to answer your questions first.
Old Oct 7, 2007 | 05:46 AM
pbn85's Avatar
no do NOT wrap the flex section with exhaust wrap. Exhaust wrap gets hard over time and will prevent the flex section from doing its job. Live with the noise till you get it fixed.
I think cattman y-pipes are more than $230 no? $130 is steep for flex section replacement...shop around elsewhere and also make sure the flex section has 1inch solid steel tips on each side.
Old Oct 7, 2007 | 08:58 PM
spdfreak's Avatar
The two times I called Warpspeed Performance I spoke to Dalas, who answered my questions and took my order.
Have you had a bad experiance? I have heard others have the same complaint as you.
Old Oct 7, 2007 | 09:00 PM
spdfreak's Avatar
If you have an exhaust leak, and you sit in the car idling for a while with not much ventilation...You can become overcome from the carbon dioxide which if you don't know can lead to alot of things I rather not mention.
Old Oct 8, 2007 | 09:10 AM
Torgus's Avatar
plug up your tail pipe with a few rags
hop under car and use your eyes ears etc.
of course this is all pointless to do as you obviously can't fix it yourself 90% of the time because it broke at a weld/flex section. which means your brining it to the exhaust shop anyways. looking is rather pointless and a waste of time other then to make you feel good about knowing where to problem is...even though you can't fix it and it's going to be diaged at the shop anyways regardless of what you say.
i find it humorous that a person cannot think of a way to determine where there exhaust leak it i mean sit and think for 2 minutes before starting a thread. honestly.
maybe i'm coming off harsh but it's simple.
edit: a flex section should be no more then $100 installed. $50 for the flex. 25$ per weld. call aroudn you can get it for $100 or under.
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
Justin Kroll
Oct 1, 2015 07:03 PM
Socalstillen
Sep 26, 2015 12:01 PM
