18x8.5 wheels with 20mm wheel spacers pictures?
ok, is it 35, or is it 45. It matters.
A wheel that width with a 35 offset will not need spacers (and they probably won't fit anyhow without rubbing.
Just buy a wheel with the correct offset and don't use spacers. That is a much better (and safer) solution....
try 45mm, I think stock is 45mm, I was wanting that wider stance in the rear with my stock wheels b/c It'll be awhile before I can afford wheels. I'll just wait and save money for wheels instead of spacers.
I’ve got 18.8.5 +33 all around, w/ 15mm spacers in the rear and 5mm in front. Effectively the offsets are + 28 front, +18 rear w/ spacers.
And no, they atre not staggerd, but the reason for the variable offsets is because:
In order to have both front and rear tires about flush on A33's, you need to use spacers if you do not want the staggered look.
http://forums.maxima.org/showthread.php?t=301966
I currently run 18x8 +38 HP Evo Lightnings with 15mm spacers in front and 20mm spacers in the back - effectively +23 offset front and +18 offset rear. Currently with 235/40/18 the front fits pretty flush but the rear is sunk in about 1cm.
I have about 2mm of clearance for my BlehmCo Z32 calipers in front. It's kinda scary actually.
I have 18x8 with a +35 offset... 245/40/18
Fronts are flush... Rear needs at least a 5-10mm spacer
I am running H&R's with HP Blues... no rubbing
Thanks for calling me out.
THAT is flush - more flush that you would ever want. 17x9 +20, 17x9 +15. The front sticks out 2cm at neutral camber and the rear sticks out by 1cm but since both front and rear are cambered out with stretched tires, they fit hella flush.
www.hellaflush.com
Offset is EVERYTHING. Thanks for playing
www.hellaflush.com
i just pickedup 20mm spacers...and its gonna be real close...
my 18" 35mm offsets will be fine due to the low pros
the stock 17" __offsets will be the problem...
I will post my progress once I get into it.(when I can get into the garage)
