To those that have removed stock air scoop.....
Old Oct 28, 2001 | 12:25 PM
Greg's2kGLE's Avatar
I just took out the stock air scoop, and I see the white reservoir is left there. I can't take it out for some reason, one bolt is all I see and when that is out, the reservoir still won't come out. Ok, back to my question...should I cover the opening to it with something so water, dirt, etc doesn't get in or can I leave it open as is? Thanks.
Old Oct 28, 2001 | 12:40 PM
Maksim2000's Avatar
Re: To those that have removed stock air scoop.....
There is another bolt on the bottom of the white box. I managed to get to the bolt and sqweeze the box from under the car ( I had to disconnect some connector on the tranny 'cos it was in a way). It was a pain to get from underside but it's doable. Now... there is som write up of someone who did remove the box by taking the battery, and it's tray.
Did i make sense ?... i think not.. but yeah there is a bolt on the bottom of the box and there is a way to maneuver the box out from the underside. Have to remove the plastic shield on the bottom of the engine compartement and disconect one connector on the fron of the tranny(next to the shifter cable).
Old Oct 28, 2001 | 12:43 PM
Well I don't feel like taking it out cuz it seems to be too much of a pain, maybe some other time...but do you recomend that I cover the opening up?
Old Oct 28, 2001 | 12:54 PM
Maksim2000's Avatar
It's not that bad man. It took me about 15 minutes to take it off while my gf was making fun of me swearing. if you wan to keep it you can just take of that black L shaped tube from the scoop to the white box(silencer?) so you don't have the hole facing upwards. If you're concerned about liquids collecting there ( I don't see how they can do it) i would just drill a drain hole in the bottom of the box.
Yeah am an enthusiast now... excitment never ceases,
Max
Old Oct 28, 2001 | 02:04 PM
UMD_MaxSE's Avatar
Got Bent?
I would just leave it in there.... it's a pain to get it out. I wouldn't worry about getting stuff in there either....
Old Oct 28, 2001 | 02:07 PM
Is it just a place to hold air? Or does it serve a purpose?
Old Oct 28, 2001 | 02:39 PM
UMD_MaxSE's Avatar
Got Bent?
I think it is some sort of a resonator that is there to cut down on noise.... but in actuality, it does not do much at all.... the 2k1 maxima doesn't even have it...
Old Jun 17, 2007 | 07:47 PM
thomasskull666's Avatar
removed it
I removed mine and now theres somethign wrong with my intake. my engine is making a weird noise and its not combusting properly. i'm gonna go put it back on and see if it fixes the problem.
Old Jun 17, 2007 | 08:19 PM
P. Samson's Avatar
FYI.........there should already be a drain hole in the bottom. Pour some water in it, it should drain out of the hole.
Old Jun 17, 2007 | 08:37 PM
Stardust's Avatar
F---ing Kangaroos
For the love of God, STOP BRINGING BACK 6 YEAR OLD THREADS!!!!!
Old Jun 18, 2007 | 05:12 AM
Bufflomike's Avatar
Sexier Than Simpson
Holy Newbie. Dug deep to find that one. Should use the Noobie Thread
http://forums.maxima.org/showthread....487272&page=76
Old Jun 18, 2007 | 09:16 AM
nismopc's Avatar
What is a resonator?
Old Jun 18, 2007 | 12:18 PM
SoonerFan's Avatar
Cletus
this thread rocks
The Frye
Sep 2, 2021 11:03 AM
Smackasmith
Feb 1, 2016 12:40 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
