Question about turn signal switch
Old Mar 13, 2008 | 07:21 PM
Arek's Avatar
Every time before you make a turn you switch your turn signal and after the turn as you turn your steering wheel back the turn signal switch is disengaging it self, well mine just stop disengaging it self. Has anybody know why?, will replacing turn signal switch fix the problem (anybody know how?) or it has something to do with the steering wheel?
Old Mar 13, 2008 | 07:22 PM
SoonerFan's Avatar
Cletus
pretty sure its in the steering column
Old Mar 14, 2008 | 10:01 PM
Arek's Avatar
I hope it doesn’t mean that I have to change steering column
Old Mar 14, 2008 | 11:46 PM
SoonerFan's Avatar
Cletus
probably just a switch at the base of the blinker stock...
Old Mar 16, 2008 | 04:27 PM
nsnrider's Avatar
it is a plastic part behind the steering wheel, not the actual steering column. Kinda hard to explain, you'll have to remove the airbag, then the steering wheel, then the clock spring and then you'll see that plastic houseing to which the turn signal stalk is bolted on. hope this helps.
Old Mar 16, 2008 | 09:13 PM
Arek's Avatar
Actually I think I know what are you talking about (Factory Service Manual helped) but I think I will let dealer fix it (I know everybody hate them - but mine is pretty good) cause I do not have Steering wheel puller required to do this.
Thank you guys for all the help
Old Mar 18, 2008 | 10:17 AM
foodmanry's Avatar
Da Roller Coaster!
It's actually not that hard to replace...you only need to remove the steering wheel column cover and there is the turn signal stalk with the base attached. Just unbolt it and unclip the wires then you can pull it out and replace with a new one.
Old Oct 10, 2008 | 06:50 AM
prekoshus's Avatar
is everybody sure the signal switch needs to be replaced? im having the same issue, i was thinking it had more to do with the clock spring then the signal switch
03VQMAX
Oct 2, 2016 09:36 AM
vybz05
Dec 10, 2015 07:38 PM
sake1bs
Sep 19, 2015 09:32 PM
BobMax
Aug 15, 2015 12:35 PM
