Need help installing Hella Supertone horns
Old Mar 16, 2008 | 09:54 AM
mist max2000's Avatar
okay so long story short i wanted to put these in (2000max btw).. well i thought it would be unplug OEM, pulg into hella and bingo.. louder horn.. yeah i was wrong..that = no sound... so im basically stumped and if anyone could throw some advice my way i would appreciate it...i drive about 70 miles round trip to work and theres alot of idiots on the highway that like to merge without looking and i need a louder horn.. so please help ..
Old Mar 16, 2008 | 10:18 AM
nismowolfe's Avatar
Did you have the hellas mounted when you pluged them in? Sometimes they use the frame of your car as there ground. So once you plug them in touch them to the metal frame of your car or where you want to mount them and as long as you have a good ground they should work. Our cars look exactly the same by the way.
Old Mar 16, 2008 | 11:56 AM
well then you have good taste..lol... yeah i thought about that after i gave up on the whole ordeal.. well thanks for the advice.. i guess ill give that a go next time i play with the car and see what happens..
Old Mar 16, 2008 | 12:36 PM
Bluesbrekr's Avatar
Doctorate in Detailing
+1 for the grounding. You may need to run a seperete ground wire. They are very sensitive, in that if it's not a solid, tight ground, they will not make a sound.
Old Mar 16, 2008 | 05:44 PM
alright.. thanks i appreciate it.. i guess ill run a really good ground to them and see what happens.. in theroy.. all i would need was the orig. + connection and a good ground and they should work right?
Old Mar 16, 2008 | 08:11 PM
ShiftVQ35
where did you end up buying them? keep us updated :-D
Old Mar 17, 2008 | 06:18 AM
i bought them off ebay lol i know i know.. but there the real deal and it was from a co. on there...im going to install them today and ill keep you updated..
Old Mar 17, 2008 | 08:01 AM
well they work..I needed to run a neg- to the battery for some reason i couldnt get anything on the frame to work but the battery solved the trick..and holy crap are they loud..so much louder then anything stock..i recommend anyone that doesnt have these to get them.. took 10-15 mins to install once i figured out what wasnt working..well worth the 50-60 bucks that i paid..the way i look at it.. if 50 bucks worth of noisemakers can stop thousands of dollars in damage from some idiot hitting me then why not..
Old Mar 17, 2008 | 09:17 AM
Teaner's Avatar
2003 Nisan Maxima
i would love to see and hear a video of this horn. could you pm me a link to it if you have the chance. Thanks!
Old Mar 17, 2008 | 01:37 PM
Bluesbrekr's Avatar
Come to Maxus and you can hear mine in person. Yes...they are hella loud.
Old Mar 17, 2008 | 04:20 PM
search for hella supertone horns on youtube.. you will find a good example im sure i dont really have the time to get a video sorry..
Old Mar 17, 2008 | 04:51 PM
Teaner's Avatar
2003 Nisan Maxima
thanks found one
Old Mar 18, 2008 | 04:31 AM
raidwolf's Avatar
did it come with a relay? if it didn't, it should have. i highly suggest using a relay. the hellas withdraw much more amperage than the lousy stock horns do. and wiring a relay is a cinch.
Old Mar 18, 2008 | 06:31 AM
trigger005's Avatar
IIRC there shouldnt be any need for the relay. i didn't use mine. just power and ground.
Old Mar 18, 2008 | 07:52 AM
raidwolf's Avatar
that's why i asked if his came with a relay, which it should have. if it's there, then it should be installed. even for some horn kits that don't have a relay included, the instructions say how to wire it with a relay. they're cheap, can be found at any electronics store, and easy to wire. these horn kits, especially the hellas, need more current to operate, so why risk frying the stock wiring? use a relay.
Old Mar 18, 2008 | 11:22 AM
hi-tek22's Avatar
the only thing i dont like about my Hella Supertones is the fact that they have that "NAIL IN A CAN" sound when you chirp the horn or (Lock doors)
Old Mar 18, 2008 | 09:06 PM
yeah ^^ thats true it sounds like a thump not a horn LOL...
Old Mar 18, 2008 | 09:08 PM
so how would u wire the relay.. lets say there were 4 points on the bottom of the relay?...
Old Mar 19, 2008 | 04:44 AM
raidwolf's Avatar
it's super easy. the numbers on each of the relay prongs correspond as follows:
30 - wired with an inline fuse to the battery.
85 - frame ground.
86 - stock horn wire.
87 - to hella horns.
make sure to ground the hellas themselves as well. i forgot what amp my fuse is, but 15 amps should be sufficient. i used 12 ga wire all over as well. and lots of electrical tape. hope this helps and good luck with the install.
Old Mar 21, 2008 | 08:31 AM
ShiftVQ35
nissan horn sucks anyway . i will be upgrading soon to hella
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
