unusual engine noise
Hi, I own a 2001 Nissan Maxima SE 20th Aniversary Edition, 5 speed manual. It only has 6900 miles on the odometer and I've changed the oil twice, once at 3944 and once at 6862.
About a week ago it started making a funny noise when accelerating in second or third gear at around 3000 rpm. It only happens when the engine is relatively cold.
The acceleration sounds fine, but on top of that is a noise that sounds like a light grinding, or like something is loose. The best way I can describe it is to say that it sounds like my car is getting over a chest cold. You know when you breathe and you hear the congestion moving? It's like that.
I'm going to take it into the dealer for work but I just want to have an idea of what I'm talking about. Any ideas on what's causing this?
Thanks,
Brian
Thanks,
Brian
My guess is that its that backpressure control flap on the exhaust that makes the annoying rattling sound at moderate acceleration. I hear it on mine from time to time but it doesn't get very cold here in Houston
so you might be hearing the same thing only exacerbated by colder temperatures.
Re: unusual engine noise
It's happened to me about 4 times in the past year. Accelerating from a stop at about 3000 rpm and it sounds like a light grinding/clanking/coughing sound. But it disappears in a few seconds and I don't hear it again; only happens when I first start driving. I'm planning on bringing this up in my next service, but if you find out anything, I'd definitely be interested.
5thGen
BC, Canada
5thGen
BC, Canada
Thanks,
Brian
Thanks,
Brian
yeah i've got it, for good i think. i haven't noticed if it's excerbated by cold temps tho so i'll have to pay better attention. i thought it was lower grade gas that caused it cuz when i use good premium, it seems to diminish or dissappear. don't know
The sound is not electronic; definitely sounds mechanical. As for gas, I only use 92 or 94 from Chevron. My next service isn't for a month or so, but I'm pretty sure they won't do anything since it's not reproducible. Since this wasn't mentioned in Maxima.Org before, I thought it might have been just me. Made me want to trade up to a 2002 'cause I thought my engine may be a bad apple. Glad there's a couple of you with the same symptoms.
5thGen
BC, Canada
5thGen
BC, Canada
I looked on autoweb.com and found this in the troubleshooting section:
Symptom: There is a rattling noise from the engine when you accelerate
Description of problem: Your car seems to run fine at all times. You notice nothing unusual except when you press on the gas pedal to accelerate or to go up a hill. Then the engine rattles like something is loose inside of it. Normally, this problem begins slowly and gets worse.
Probable Causes:
1. Your ignition timing needs adjusting.
2. The engine is overheating.
3. You have a loose vacuum hose on the engine.
4. You bought low-octane fuel even though your owner's manual says to only use high-octane fuel.
5. There is an excessive amount of carbon built up in your engine.
6. You have a problem with the electronic engine control system.
Probable Causes:
Interesting...I thought it might be a bad batch of gas. I think I may have put in 89 octane instead of 93 a few times without thinking.
Nissan service didn't find anything wrong with my Maxima. To be honest, I'm not surprised. The service manager said they took it out twice and couldn't duplicate the noise, so it must have been bad gas.
I haven't heard the noise since I put in a batch of Chevron 93 Octane (with techron!).
ballerchris510
Sep 11, 2015 05:29 PM
