Thinking of buying a 5th/5.5 Gen? Please post all questions and info here....
Old Mar 23, 2010 | 06:40 PM
  #601
mandyfig's Avatar
That's the strut bolt for the tensioner adjustment.
Old Mar 23, 2010 | 10:16 PM
  #602
ewles's Avatar
ahh now that you say that, i can see that cleaaaaaarly, should there be something screwed in the top or just open threads on the inside as i was seeing?
i am going again on the weekend to view/maybe buy the car, with my mechanic, but wanted to be sure of THIS before i went
Old Mar 28, 2010 | 09:03 PM
  #603
johncg316's Avatar
Question......I am thinking of buying a Maxima and I would want to install an in-dash Navigation system - DD size. Is there a how to on doing this or is it not possible?? Any help is greatly appreciated.
Thanks,
Old Apr 1, 2010 | 06:28 AM
  #604
Max Gluteus's Avatar
My 2000 is fine but like many 5th gen owners the O2 sensor is a problem. My ses came on P0138-39 and I have not yet replaced the sensor. I keep getting the wrong part. They sent me one with too short of wire hook ups. But now the car started bucking and showing extreme loss of power. I just hope I'm not encourgaging more damage (cat?). I hope when I install the new sensor(s) I'll be back to normal.
The bank 1, sensor 1 is an issue in that the parts guys look for front left and right or back left and right. I have not been able to determine which is which. The sensors are all the same, it appears, its just the length of the wire hook up that's different. I hope.
I replaced the maf last Fall and other than these issues this 2K Max has been great.
Old Apr 5, 2010 | 10:20 PM
  #605
glekid's Avatar
im thinking of getting a 2000 maxima with 83,000 for around 3700
Ive been reading reviews on Coils having to be replaced as one of the main gripes
Should I pass on car, like is it even worth it
Old Apr 9, 2010 | 11:38 AM
  #606
Sunyata's Avatar
I am thinking of getting a 2002 Maxima with 80/90k miles for about 4500. Luckily, a car dealer who lives at the building I work at is sympathetic to my car troubles and is willing to sell me something at cost + a few hundred dollars.
Since the car I had been driving was a 2000 Camry, reliability is a must for me. Other than regular maintenance, that car needed nothing for all its 130,000 miles. Overall, is the Maxima a pretty reliable car? Is it fairly safe to say it will last me to at least 200,000 without any major four-figure repair costs?
Is the gas mileage as high as advertised? (26-ish highway?)
Also, how is insurance on the 02 Maxima? I recently was in at at-fault accident.
Lastly, since the dealer can basically get me the model I want, do any of you have any other recommendations for me? Something with a bit of style, but also very reliable and not entirely predictable or bland?
Thanks a lot for your help!
Old Apr 9, 2010 | 11:47 AM
  #607
mandyfig's Avatar
Best for you is to read posts/threads and find out for yourself. Welcome!
Old Apr 9, 2010 | 11:51 AM
  #608
mandyfig's Avatar
Basically, go find the car you want and buy it. Insurance cost, that's entirely up to your history, nobody can predict that.
MPG, again, you can do some basic research, just reading through the posts here will educate you.
If you had specific questions relating to real issues, we can chime in. General questions, you alone can decide.
Anyway good luck.
Old Apr 9, 2010 | 12:06 PM
  #609
homeyclaus's Avatar
Thanks,
Youtube has a gread video on how to get the stereo out, and Crutchfield sells adapters, harness adapters and anything else you could want to make that fit and look right. It's not that hard.
Old Apr 9, 2010 | 12:45 PM
  #610
NIGHTMAREuki's Avatar
if the car was properly maintained it will last.
gas mileage depends on how heavy your foot is, but based on that you're coming from camry you will probably see worse than advertised for first few month untill you get used and tired of tearing up the road. maxima is completely different beast than a camry even more so if you had 4 cylinder one.
insurance shouldn't be too much of a problem, comparable to other cars in category
you need to check 2 things in maxima, engine and tranny.
dip stick should be clean, if the is sludge any where, especially in the dips or all the way up top around the screws pass on the car it means oil change was not priority of previous owners. Tranny should shift without hesitation and be smooth especially when you accelerate had then let go of the gas, there should be no big bangs or jerks.
and most of all because you're not familiar with this car drive another one and make sure the one you want to buy is not lacking in power, because for someone who is not used to vq even when its not working properly will seems fine, been there
Old Apr 10, 2010 | 06:26 AM
  #611
Kwolfe's Avatar
I hope someone can help...
I have a 2003 GLE with 131,000 miles on it. I get a little chatter first thing in the morning but it goes away real fast. I am pretty sure it is the VCT because I change the oil every 3,000 miles and there is no sludge build up anywhere. I even had a small oil leak around the oil pan so I took it and had it resealed. The guy that did it said the pickup was clean and the pan was clean too so I am sure the oil pump is working fine. Will the VCT shatter at low RPM's cruising down the hwy? It goes away when I give it alittle gas. I also only use high octane gas and changed the fuel filter last month.
Any info would help, thanks.
Old Apr 15, 2010 | 02:00 AM
  #612
Sunyata's Avatar
So my connection is going to use the dealer-only auction site Manheim in order to find my Maxima. I'm thinking I want to spend at most 6k, which should allow me to get a pretty solid vehicle (~90k miles 2002 GLE).
My question is, is there anything "better" about this dealer-only auction sites? Is there any way to know how the car was maintained, or if something like the timing belt will need to be replaced somewhat soon?
Old Apr 15, 2010 | 11:34 AM
  #613
johny walker's Avatar
6spd mt fill plug.
I can not find the fill plug for my manual transmission and the thread in here aboun changing manual transmission fluid on my 02 is not working for me.
Old Apr 15, 2010 | 02:16 PM
  #614
never mind im just retarted and dident look hard enough
Old Apr 15, 2010 | 04:43 PM
  #615
mandyfig's Avatar
So did you find it?
Old Apr 15, 2010 | 10:42 PM
  #616
ya.
Old Apr 16, 2010 | 05:23 AM
  #617
mandyfig's Avatar
Where was it located?
Old May 2, 2010 | 10:25 AM
  #618
2kmaxseblack2k's Avatar
I am needing to swap 02-03 xenon in my 00 max. Can anyone tell me if they're plug and play?? They're currently in my boys 00 gle and I just was wanting to put them on my se...anyone shed some light?? PLEASE HELPPPPPPPP
Old May 13, 2010 | 09:58 PM
  #619
nachy1's Avatar
nice
Old May 16, 2010 | 08:21 AM
  #620
MAXIMA_STYLE's Avatar
so ive been looking.....
Ive been on the hunt for another max now...i found this
http://www.autotrader.com/fyc/vdp.js...standard=false
Does anyone think this is a decent deal i kbb'd it and they say 7200-7400... he wants 8900 you think i should offer him 7400?? it has a greddy catback aside from that it looks stock
Old May 16, 2010 | 08:42 AM
  #621
greenwood's Avatar
gotta love the AE. i know i love mine! if you can talk him down go for it, i picked mine up for $6200
Old May 16, 2010 | 08:46 AM
  #622
e-subliminal-2's Avatar
I bet he posted it above the kbb so people would think they're getting a deal on it. He prob picked it up from auction for around 45. I personally wouldn't pay more than 6 tops. That's just me, these things are sadly losing their value quicky. I got my 5.5 gen with 68k on it a year ago for 7.....
Old May 16, 2010 | 09:17 AM
  #623
Rochester's Avatar
The AE is special. No one would argue differently. But you already know what the 3.0 liter is like in your current ride. The AE won't be that much different. (There's a 5hp bump, I think.)
By my reasoning, if you're wanting another 5th gen, then you should be looking for a 5.5. Not too much cost variation between an 8 year old car and a 9 year old car, but a BIG difference in the engine. Your priorities may differ.
Looking at the AutoTrader photos, it sure looks clean from the outside. However, that fugly fart-can exhaust would give me serious pause to question the previous ownership. Just saying. (I'm a dual-tip snob.)
Old May 16, 2010 | 09:21 AM
  #624
No its not a matter of priorities at this point,its a matter of findin a 5.5 gen 6 speed with that mileage for the price i want and not to mention the color....
Old May 16, 2010 | 09:30 AM
  #625
Rochester's Avatar
I get that about color... pearl white is very attractive on the Maxima.
Searching through AutoTrader, that seems about the going price for a 5.5 6MT. Tough call. I'll say it again, the 2001 AE is a special car.
Kind of like this $10K Titanium Edition.
Old May 16, 2010 | 09:36 AM
  #626
yea i see...the only problem i have here is i got a 5th gen and my lip wont fit a 5.5 gen, i wont need the lip if i buy the ae model lol just my rims system and well its already got my greddy on it too so i wouldnt need that but who knows i emailed em and im gonna talk to em when they call and see what they can do with it, my max is getting paid off this week i owe 350 on it lol had it for 2.5 years and drove WAY to much with it...i got it at 99k and it now has 205k on it...
Old May 16, 2010 | 10:15 AM
  #627
cmax1's Avatar
The car has 100k+ miles and its coming up on a decade old.. Try to get it for 6500 if not leave it alone..
Old May 16, 2010 | 10:39 AM
  #628
2000_MAXIMA_KING's Avatar
if u want the best deal find someone that goes to the dealer auctions that can find u one thats how i got my 00' max i only paid $2400 for it n all it needed was the radiator
Old May 16, 2010 | 10:51 AM
  #629
This car is soon to be a decade old dude... okay it's an "ae" edition, as rare as they are my buddy got his at auction price for around 4k. I think even cheaper. I got mine for 7k as stated before with 68k. 3.5 6mt fully loaded minus navi.... If you are patient enough you'll find a good deal on a car with less miles.. He's asking 9,000 for a decade old car with 100k. I'm not bagging on the maxima at all. But his asking price is extremely high. I wouldn't pay over 6k.
Old May 16, 2010 | 12:36 PM
  #630
yeh i figured as much, its been on his lot for 5 months or more now...i noticed it 5 months ago and he still has it LOL
Old May 17, 2010 | 12:07 AM
  #631
01-maxima-24's Avatar
The lip can be sold easy(to me ) get a 5.5 Gen. If I'd known the difference 3 yrs ago that's what I would have done, 3.5 engine and hids from the factory. Not a big difference in price either, be patient
Old May 17, 2010 | 12:34 AM
  #632
BronxSleeperMax187's Avatar
your gonna get raped....look what I found in my area for less
2000 Nissan Maxima 5 spd low mileage - $1 (edison nj)
Date: 2010-04-15, 3:39PM EDT
Reply to: sale-bsdyv-1693833672@craigslist.org [Errors when replying to ads?]
2000 Nissan Maxima 5 spd manual trans. Low milage car with only 91k miles. Black interior all maintenace records $7k or best cash offer.
Call Matt 908 405 4326
  • it's NOT ok to contact this poster with services or other commercial interests
PostingID: 1693833672
Old May 17, 2010 | 12:37 AM
  #633
CraigSE's Avatar
Pearl white AE.... Awesome.... Best color ever
Old May 17, 2010 | 12:42 AM
  #634
crystalline's Avatar
I got my 02 6mt for 7k back in September. I only paid that much because the dealer had a list of stuff he replaced (half of it done wrong or not done at all I came to discover) and because he said he would fix everything wrong with the car that happened within 30 days (they did the inspection at this dealership and didn't cover the strut and axle that I discovered needed to be replaced within the first two weeks) I only consider it a good deal because they took my explorer for 3k trade in...
Old May 17, 2010 | 01:13 AM
  #635
Old May 17, 2010 | 01:30 AM
  #636
a33_ridah's Avatar
the original car in question is overpriced. ae or not.
keep hunting. i wouldnt pay 5 for that car personally. i am more than happy with a 2000 i picked up few months back for 1500. yup 1500. 5 speed gxe to add to my 03 se te. my other baby.
Old May 17, 2010 | 05:04 AM
  #637
Puppetmaster's Avatar
http://forums.maxima.org/5th-generat...info-here.html
Old May 20, 2010 | 09:35 PM
  #638
rockboy's Avatar
Hey I'm new here & I plan on buying a Maxima in the next few weeks! I always Wanted a Maxima I have two in mind
A 2000 white maxima for $5,000 with 103k miles also the carfax came back clean is this a good deal?
http://www.lemonfree.com/48147926.html
2002 green Maxima with 128k for $5,200
http://www.dpaa2.com/inventory/detai...=9150#tippytop
Which one would be the better deal?
Thanks in advance!
Old May 24, 2010 | 04:59 PM
  #639
Herofmine's Avatar
heyyy finally i got 5.5 gen Maxima 3,5 with 6 speed GREAT CAR
i used to have 2001 Maxima would never recommend to anyone
i had a lot of problems with that car! never buy 00-01 max!
go to 5.5 gen!!!
Old May 30, 2010 | 08:08 PM
  #640
Nucho's Avatar
Regarding the oil burning on 3.5L engine I manage find a solution. I use synthetic oil which has all but eliminate the need for constant oil burning. I use slick 50 from time to time which appears to help.
