P0135 PO155 P0141 AND o2 simulator...help
Old Apr 13, 2008 | 07:12 PM
kramarz99
did some research and couldn't`t find it. there is tread how to install o2 sim on California edition maxima. I got 2000 federal edition and getting p0135 and p0155 ses. just want to know how to hook up 02 simulator. got the dual output one. can someone post some pics of location where to splice and attach o2 simulator?
thanks
Old Apr 14, 2008 | 06:05 AM
kramarz99
does anyone know how to get ridde off P0135 and P0155 alarms with 02 simulator? where and how to hook it up?
Old Apr 14, 2008 | 08:08 AM
kramarz99
some help, please..................
Old Apr 14, 2008 | 08:58 AM
Puppetmaster's Avatar
Aren't those heater codes for the primary sensors? The sim will not fix those; the sim is only meant for voltage codes on the secondary O2s.
Also, are you sure you have a P0141? That's for a Cali spec car. That's a heater code for a secondary, that will the sim will not fix either.
You have to get new sensors or some resistors to simulate the heater circuit.
Someone correct me if I'm off base, because I'm on vicodin now, lol.
Old Apr 14, 2008 | 09:07 AM
kramarz99
see, before I had P0141 SES..after I hooked up o2 sim got 135 and 155? why would it do that? if I get resistor, wherehow do I install it?
this would be nice write up for a lot of members. I have been looking for write like this and couldn`t find it...
Old Apr 14, 2008 | 09:11 AM
sergey85's Avatar
(p0135)This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
po155 (heater circuit bank 2 sensor 1) and P0141 O2 Sensor heater Circuit malfunction these are probably related. so like puppetmaster said probably need to replace them or take a look at it. i think the simulatar is used when getting the y pipe i believe for the secondary o2 sensors good luck
Old Apr 14, 2008 | 09:44 AM
kramarz99
so there is no way to use simulator and bypass those? and, are we talking about 1 sensor or two?
Old Apr 14, 2008 | 10:04 AM
SoonerFan's Avatar
Cletus
P0135 - Front O2 Sensor Heater (Bank 1)
P0141 - Rear O2 Sensor Heater (Bank 1)
P0155 - Front O2 Sensor Heater (Bank 2)
3 sensors
Bank 1 - both sensors
Bank 2 - Primary sensor
why dont you just replace the sensors
Old Apr 14, 2008 | 10:10 AM
kramarz99
just want to get ridde off SES light for good...how can I do that?
Old Apr 14, 2008 | 10:13 AM
SoonerFan's Avatar
Cletus
replace the bad O2 sensors
Old Apr 14, 2008 | 10:15 AM
kramarz99
this will sound stupid, but how many sensors? just don`t laught...
Old Apr 14, 2008 | 10:17 AM
http://forums.maxima.org/showpost.ph...53&postcount=8
Old Apr 14, 2008 | 10:19 AM
kramarz99
damn...that is like $300...any other options?
Old Apr 14, 2008 | 10:20 AM
SoonerFan's Avatar
Cletus
here are the locations
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
you only have 3 sensors...all of them need to be replaced
SoonerFan's Avatar
Cletus
dont drive your car
Old Apr 14, 2008 | 10:40 AM
kramarz99
Old Apr 14, 2008 | 11:03 AM
SoonerFan's Avatar
Cletus
why not? what will happen if I do drive it?
do you know what the sensors are for?
Old Apr 14, 2008 | 11:11 AM
kramarz99
on that 4 wire sensor, are thos two white wires the same?
Old Apr 14, 2008 | 06:53 PM
kramarz99
is it possible not to get power to o2 sensor?
Old Apr 14, 2008 | 07:19 PM
SoonerFan's Avatar
Cletus
if it isnt plugged in
Old Apr 14, 2008 | 07:34 PM
kramarz99
so that what it was....lol
one more thing, on for wire sensor, how do you tell difference between thos two white wires?
how can you what is what?
Old Aug 8, 2008 | 08:54 PM
Lugubrious's Avatar
I got the same problem PO135, PO155 and PO141. i have a Y pipe and hi flow cat converter with 140,000 plus miles. Car still runs like a champ! I've changed out all three O2 sensors and now I'm thinking that it might be the ECM. It might also be getting the wrong O2 sensors? Any suggestions?
Old Dec 13, 2008 | 01:04 PM
mhernand99's Avatar
I had the same p 0135 code come up on my 2001 maxima. I went ahead and changed the O2 sensor but my local auto parts store only had the NTK 24619 and not the Bosch. The Bosch is much bulkier so I am wondering if the NTK does not have the heater element. Has anyone used the NTK sensor?
I am just hoping the check engine light does not come on again.
Old Feb 22, 2010 | 06:24 AM
williamgd2's Avatar
There is a chance he is not getting power to the sensors. Check fuse #8 on the in car fuse block.
sake1bs
Sep 19, 2015 09:32 PM
Kruppa
29
Jan 31, 2014 02:23 PM
yazz
May 21, 2011 01:57 PM
T_Dwyer88
Mar 4, 2009 06:22 AM
dhaney
Apr 16, 2007 10:11 AM
