Engine Clatter
Old 05-14-2008, 03:27 PM
2002GLE's Avatar
Engine Clatter
Hey guys I got one quick question. Every now and then when I start my car i get this clatter from the engine bay that last for about 2 seconds or so and then it goes away. Its really hard for me to describe and cant record it because it happens randomly. Typically in the mornings and today it happend late afternoon. After it happens once in a day it doesnt re-appear. The car is 100% stock, changed the oil recently with 5w-30, and it just turned 23k miles. Im not sure if I should be worried or just ignore it. Any help will be appreciated.
2002GLE is offline
Old 05-14-2008, 04:06 PM
NisTech's Avatar
it's common on these engines. It's the timing sprocket. There is a bulletin about it too.
I wouldn't worry about it.
NisTech is offline
Old 05-14-2008, 06:17 PM
jasonmax's Avatar
like this one?
http://www.youtube.com/watch?v=UzwiMWC_9EQ
jasonmax is offline
Old 05-14-2008, 06:29 PM
2002GLE's Avatar
actually exactly like that one...just the beginning part
2002GLE is offline
Old 05-14-2008, 07:05 PM
Professor's Avatar
http://www.youtube.com/watch?v=OZW2lprSyNU
least it aint like mine
Professor is offline
Old 05-14-2008, 07:18 PM
808MAX-SPEC's Avatar
I don't know about the clatter sound however, that ticking noise in both the videos, it sounds similar to mine. That ticking noise on my max is coming from the alternator. The ticking only goes away when I stick it in N, every gear including P it's there. I do have to change out the serpentine belt so I'll have my tech guy check the alty at the same time.
808MAX-SPEC is offline
Old 05-14-2008, 07:27 PM
jasonmax's Avatar
Originally Posted by Professor`
my engine has your knocking noise too. It's very low knocking and the position is low too.
jasonmax is offline
Old 05-14-2008, 08:56 PM
Professor's Avatar
many ppl tell me its the timing tensioner but iam not to sure on that, since i disabled the middle injector it gets worse
Old 05-15-2008, 12:00 AM
jasonmax's Avatar
I believe it's the rod bearing but normal for engine like yours and mine.
jasonmax is offline
Old 05-15-2008, 02:19 AM
Sunglasses required..
VQHP's Avatar
Sorry to say but you guys are all wrong.........Tell you what is wrong 100% sure this is you're problem. As we could see on the youtube clip on 00.09 sec. I have the same problem. Took her to the dealership, they did a engine diagnosis. Found that it needs a rear cat and gaskets. They dropped the whole exhaust. Parts and labor is $1100.00, I live in California it's pretty high price.It's that noise on 00.09 sec right.................JASONMAX supplied.
VQHP is offline
Old 05-15-2008, 01:04 PM
2002GLE's Avatar
Yeah its the sound made at .09 in the jasonmax video...but if it is the rear cat and gasket wouldn't it occur everytime.
2002GLE is offline
Old 05-16-2008, 09:06 AM
NisTech's Avatar
yes exactly like that one. It's common like i said and i heard it also on many 350 z before they were sold with only 6 kilometers on them.
Like i said i could have done the tsb myself for free but it did not bother me.
NisTech is offline
Old 05-16-2008, 09:08 AM
NisTech's Avatar
the noise when the cats rattle is more persistent and it happends at 1000- 1500 rpm and it rattles at light accel. 2 different birds!
NisTech is offline
Old 05-16-2008, 09:39 AM
boris's Avatar
Actually it is 0.3 second long on the video and i would consider it as a light case (yet). Mine does it for 2 sec. now and is getting worse. What i can say it has nothing to do with an exhaust and coming from the passenger side of the engine bay. TSB says it's chain tensioners.
boris is offline
Old 05-16-2008, 10:01 AM
VQHP's Avatar
Yes it occurs all the time I start my car, or everytime I give it a light rev..........
VQHP is offline
Old 05-16-2008, 10:06 AM
VQHP's Avatar
Like I explained to 2002GLE, it does rattle at a light acceleration [two different birds!]
VQHP is offline
Old 05-19-2008, 06:27 PM
rosader's Avatar
I have a chattering noise as well. i have had my 03 6spd 73k miles for 3 weeks now with no problems then today i went into the store for 30 min and came out and started it and it sounded almost like a broken fan??? as i pulled away it got louder and more severe but after about 20 mph it went away then i came to a stop light and it started doing it again and the rps fell real low then it died. i started it again but it had trouble staying running and it continued to make the noise. I had to keep it at 2k rpms while idleing to keep it running. i drove about 1/4 mile to my house and pulled into the driveway and let it idle and it would not make the noise anymore and it acted like nothing ever happened. I drove around the block to make sure and it drove just fine. please somebody tell me WHAT IS GOING ON???
rosader is offline
Old 05-20-2008, 04:36 PM
rosader's Avatar
can anybody help me with the above question? I don't mean to hijack the thread but i am a noobie and cant start threads yet. I have also used the search tool with no luck
rosader is offline
Old 05-21-2008, 11:53 AM
rosader's Avatar
Well i dropped it off at the nissan dealership this morning and hopefully they will figure it out.
rosader is offline
Old 05-21-2008, 05:19 PM
detailerdaveb@gmail.com
maximadave's Avatar
When I get a fresh oil change, I don't have the cold start chatter. After about 1K-1500 miles after the oil change, the cold start chatter comes back.
maximadave is offline
Old 05-21-2008, 05:56 PM
zoner's Avatar
Guys - that noise in the video is just a lifter ticking. Nothing to worry about.
zoner is offline
shilov
02-19-2024 09:40 PM
James92SE
142
01-02-2024 09:23 AM
msellas
09-23-2015 09:16 PM
Socalstillen
09-20-2015 11:46 PM
seesole
09-14-2015 12:38 PM
Quick Reply: Engine Clatter
