Need to paint muffler "sleeve", what paint to use
Old Jun 4, 2008 | 10:17 AM
merlin2375's Avatar
My 5th gen SE came with the sleeve that goes over the two exhaust tips. Well all the winters have killed it and it's quite ugly. I took it off and need to paint it.
Can anyone recommend a good paint that can withstand the temperatures, look good, and last for a long while (assuming it's prepped and painted correctly)
Hoping to paint mine something that looks close to what the car did when it was new..."stainless" color I guess.
Thanks!
Old Jun 4, 2008 | 10:37 AM
phatboislim's Avatar
GET RID OF EM AND GET SOME MORE TIPS...
Old Jun 4, 2008 | 10:39 AM
SoonerFan's Avatar
Cletus
get the magnaflow tips
Old Jun 4, 2008 | 11:18 AM
Kevlo911's Avatar
Kevlo for President
Why would you do a mod that doesn't help performance
j/k
Any high temp engine paint should hold if you dont wanna dish out money on aftermarket tips.
Old Jun 4, 2008 | 02:51 PM
Drockb418's Avatar
http://www.caswellplating.com/vht/vht_high.htm
Old Jun 4, 2008 | 05:51 PM
Derrick2k2SE's Avatar
High temp paint for a BBQ works well for exhaust. Just be sure that if you are priming it you use a high temp primer too.
Old Jun 4, 2008 | 09:01 PM
4DSCDriver's Avatar
Check the label...most BBQ paints don't reqiure priming.
You know you can get get some cheap screw on tips from autozone. Might look better that a rattle can paint job.
Old Jun 5, 2008 | 12:25 AM
CMax03's Avatar
Check with Thermal Research, Borla or Magnaflow for some real SS tips!
Old Jun 5, 2008 | 12:34 AM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
G2 paint or VHT engine enamel both have well above 1000 degree Fahrenheit continuous use tolerance.
Old Jun 5, 2008 | 05:16 AM
Prophecy99's Avatar
like they said.... High Temp paint.........
Old Jun 5, 2008 | 06:23 AM
merlin2375's Avatar
Thanks for the replies guys. I was going to get some tips from autozone but they are just cheap and would probably just out again real quick, that's why I was thinking about painting them for something that lasts a little longer.
If I did get the magnaflow tips (they are stainless) does anyone know the measurements required for the stock SE tips. I measured about 3" ID and 7" long. Anyone confirm or know which magnaflow is right?
Also, any tips on where to get them. Will post pics if I paint
Old Jun 5, 2008 | 01:42 PM
CMax03's Avatar
Those will fit fine! Just cut your existing itty bitty tips down to about 2-3" and butt the new tips all the way to the Muffler end plate and tack weld it in about 4 spots. Just make sure they're centered and the slant cuts are truly vertical! It's alot better than the Oem tip shroud...
Old Jun 5, 2008 | 02:43 PM
mooseq30's Avatar
VHT pick it up at lots of places, works well
if not bbq paint works, put it on heat up the car by driving it around, then it will quick dry put another layer if its not the desired thick color u want!
Old Jun 5, 2008 | 02:48 PM
SoonerFan's Avatar
Cletus
magnaflow tips
Old Jun 5, 2008 | 04:11 PM
AceofSpds's Avatar
wat
j/k
+1 and
Go to an autoparts store, there should be a 12'by9' section of high temp paint.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Turbonut
46
Oct 21, 2015 08:28 PM
TheMafia
Sep 4, 2015 08:26 AM
