umintza projector headlights w/ angel eyes
Aug 3, 2008 | 11:01 AM
  #41
you are better off using stock 02-03 headlights for lighting and appearance.
but thats just me...
Aug 5, 2008 | 07:47 AM
  #42
i ordered a set to replace my oem headlights.i can't afford to buy oem headlights too expensive
Aug 5, 2008 | 08:28 AM
  #43
2 new ebay headlights are what 600 shipped?
what are you doing with your old headlights and whats wrong with them?
Aug 5, 2008 | 08:40 AM
  #44
tabs got broken cause i was too rough drilling out the rusted torx bolts.drive side light hid isnt working and the assembly got cracked open from a bird hitting it .passenger side light has small chips and dents and i have tryed wet sanding to get blemishes out but it still gets faded and absorbs dirt.I am the 2nd owner of car and i think the previous owner replaced the passenger side light with an ebay one and they dont seem to be the same quality as the other side.The ballast is phillips on one side and another brand on the other side .
Aug 5, 2008 | 09:14 AM
  #45
Will you send me your old lights? i'll pay for shipping. i want to try something...interesting with them.
Aug 5, 2008 | 09:48 AM
  #46
i was gonna experiment with them myself. if i change my mine i will let you know
Aug 5, 2008 | 12:30 PM
  #47
Umnitza, do you offer just the ccfl rings if we already have the ebay lights or do you have something in your inventory that will fit the lights from another car?
Aug 6, 2008 | 01:45 PM
  #48
i guess there busy and havent been able to take pics
Aug 19, 2008 | 06:11 PM
  #49
Sorry guys, we really got busy over the last two weeks.
Some custom work etc.
Here's a sample:
Still working on pictures on the car.
  #50
one more:
Aug 19, 2008 | 06:14 PM
  #51
how about an output shot...
Aug 19, 2008 | 06:37 PM
  #52
We all really wanted to see a cutoff picture.
Aug 20, 2008 | 11:37 AM
  #53
looks like the folder is open for directory listing...
what appear to be cut-off shots:
http://www.umnitza.com/albums/Nissan...ximacutoff.jpg
http://www.umnitza.com/albums/Nissan...imacutoff2.jpg
Aug 20, 2008 | 08:12 PM
  #54
bite the bullet and pay 750 for a retro with TSX
Aug 20, 2008 | 08:27 PM
  #55
if that is correct i might get a set from them
Aug 20, 2008 | 11:27 PM
  #56
Quote: one more:
These look great. How much, shipped to 78212?
Aug 21, 2008 | 07:44 AM
  #57
Those do not look great, they look like crap. Plain and simple- these are just a set of eBay projector headlights with a h3 HID kit. The projectors just don't have a good beam pattern and there is no modification/adjustment that will fix that.
Sure it looks bright in those cutoff pictures, the projectors are only about 10 ft away from the wall, give or take, way to close to be able to say anything meaningful about the beam pattern. More accurate pictures should be at least 25ft from a wall, probably closer to 40ft. But even in those 2 pictures you can see hints of an uneven beam pattern with clusters of hot and cold spots that is characteristic of these projectors.
It is well known on these forums that the projector headlights are weak and perform poorly. Slap a hid kit in them and all you have is a poor beam pattern that has brighter hot spots making the cold spots that more evident.
Aug 21, 2008 | 09:19 AM
  #58
Quote: Those do not look great, they look like crap. Plain and simple- these are just a set of eBay projector headlights with a h3 HID kit. The projectors just don't have a good beam pattern and there is no modification/adjustment that will fix that.
agreed...the second pic you can see the hot spot concentrated in the center and it's dim on the rest of the cutoff...i'm sure the light output don't spread out as evenly as oem setups.
spend your money wisely, put some real projectors in those headlights so you don't get disappointed later on. any people that knows about lighting should agree with this.
here's what a good output should look like...notice how evenly spread the light is?
Aug 21, 2008 | 02:18 PM
  #59
now that is pretty ^
Aug 21, 2008 | 03:05 PM
  #60
and this is what you see when you have weakie halogen.
Aug 21, 2008 | 05:23 PM
  #61
^ haha can't see anything with that =P
Aug 21, 2008 | 05:39 PM
  #62
i think i need glasses now looking at that bad cutoff. Low you had a nice cutoff with your TSX projectors
Aug 21, 2008 | 07:32 PM
  #63
$750 would be a good price if we knew the exact components used in the headlights; Namely, the projector make. I've considered redoing my retro with black headlights and E46 single-xenon headlights so it's easier to flash people... Or actually finishing the retro on my old 00/01 headlights.
Aug 21, 2008 | 09:02 PM
  #64
stock ftw....
Aug 22, 2008 | 03:21 AM
  #65
umnitza, do you have the CCFL rings for those of us who already have the projector headlight?
Aug 22, 2008 | 10:24 AM
  #66
yes, but those are unmodified pattern shots we took prior to the final ones on the car. the actual output is quite good and frankly, the camera we took it with is not good. The real output on the wall was much better. The second shot was taken from 50' away and the first one was 20' away. The actual pattern is very even and yes, while there is a hot spot, the spot isn't as pronounced as it is with this crappy camera we used.
Quote: if that is correct i might get a set from them
They are correct but not corrected.
Quote: umnitza, do you have the CCFL rings for those of us who already have the projector headlight?
yes, we offer a retrofit kit for them it's $129.
Aug 23, 2008 | 05:51 AM
  #67
Umnitza, i dont belive you are doing anything else besides pre installing a hid kit. I will say it again there nothing you (or anyone) is going to do, to modify that project and fix its shortcomings.
The problem isn't just the big hot spot in the center, its all the other hot spots those projectors make and the darkness between them . Please go ahead and take a good quality photos with you good camera, of these projectors at 50 feet, on black pavement against a white wall. Maybe then you will see what i am talking about. Because it seems to me, for a guy who sells automotive lighting - you have a pretty bad eye, when it comes to evaluating what good lighting.
Aug 23, 2008 | 06:13 AM
  #68
Habbie whats up man. j23a45m from bmf
i know your work is always worth the money, my 5.5 might be here soon for my girl and my order will be in for some hid's for the fogs. keep up the good work man
Aug 23, 2008 | 09:26 AM
  #69
Aug 23, 2008 | 12:29 PM
  #70
he obviously is saying that he is going to be placing in an order for some fog hids from you....
Aug 23, 2008 | 12:50 PM
  #71
So do these headlamps have different projectors or atleast lenses from the ebay ones?
Aug 23, 2008 | 12:55 PM
  #72
Quote: So do these headlamps have different projectors or atleast lenses from the ebay ones?
Aug 23, 2008 | 03:19 PM
  #73
lol that's what we've been trying to find out...but still after so long that question is still unanswered and avoided =/
Aug 23, 2008 | 03:21 PM
  #74
No, they are no different on the lenses, although we are exploring that idea and may have that as an option shortly.
No, what we do is modify the housing that the bulb sits in to get a cleaner better light pattern.
Aug 23, 2008 | 04:02 PM
  #75
Still waiting for shots of the cut off from one of your "modified" headlights -like you promised over a month ago, but failed to deliver. And don't forget to use your "good" camera LOL.
Aug 23, 2008 | 10:56 PM
  #76
this reminds me of bimmerfourms they have the same prob
Aug 23, 2008 | 11:41 PM
  #77
Quote: No, they are no different on the lenses, although we are exploring that idea and may have that as an option shortly.
Not really trying to jump on the bandwagon but just curious how will the housing will help project a better beam. If the ebay lenses are crap to start with, then I think their performance is really limited even with modification. I'm really interested in seeing the end results because it would be a cheap way for better brighter lighting.
Also... housing and reflector bowl are two different things, right?
Aug 25, 2008 | 01:51 PM
  #78
Quote: The projectors in those headlights are pure crap, the projectors have horrible light distribution and give a beam pattern littered with hot and cold spots, the angular reflector bowl is the problem and there is no modification that is going to get around that.
Short of replacing the projectors that come in those housings (ie retrofit) there is nothing that can be done to improve the perfommance of those headlights.
I'm a newbie to the forum thing but I believe im posting correctly. Projectors from ebay just like everybody else have said are absolute garbage. I strongly recommond an Oracle Halo Kit. Although a bit hard to install for newbies with little experience in custom work you can find an installer (such as myself) that does them for a living. Here are a few pictures...
I got UV halo rings with a 12000k D2R HID bulbs. Strongly recommend this kit instead of the cheap ebay projector rip off.
You get to keep your stock headlights just customizing them without loosing any visibility. :-)
Aug 25, 2008 | 02:04 PM
  #79
I thought we're talking about the projector and not the halo rings? But cool stuff btw.
Aug 25, 2008 | 02:27 PM
  #80
anybody in new jersey wanna try and hook my projector lights up ?
