Eibach owners - cut your bump stops!
Old Jul 14, 2008 | 07:02 AM
n3985's Avatar
大陆弟弟
When I had my Eibachs installed originally the installer assured me that the bumpstops did not need to be cut, even though instructions stated 25mm and 30mm cut front and rear respectively.
Low and behold after the springs settled, regardless of what my Illuminas were set to, any bump over 1.5" (est) I would bottom out with a loud crash and my interior shaking.
This weekend finally had my front bumpstops cut by djfrestyl whom I HIGHLY recommend for suspension work in NJ and all is well!! I no longer crash and fly over bumps like before because my shocks are actually doing their job now!
I have searched and seen many threads where people argued over cutting bumpstops for Eibachs, my recommendation is that if you have perfectly smooth roads then don't bother, anywhere else do it!
Old Jul 14, 2008 | 07:19 AM
MaXiM@KiD's Avatar
MaXXiN
interesting..what year is your car?
Old Jul 14, 2008 | 07:22 AM
n3985's Avatar
大陆弟弟
02 I35
Old Jul 14, 2008 | 08:43 AM
maxima-junky's Avatar
Do third gens have these bumpstops? If so can someone post up a diagram or pic of it's location. My car dives into dips the same way. I drove someones third that didn't do that and I'm thinking this may be part of the problem.
Old Jul 14, 2008 | 08:46 AM
maximadave's Avatar
detailerdaveb@gmail.com
I cut my previous oem bump stops and they dicinigrated over time.
Old Jul 14, 2008 | 08:55 AM
phatboislim's Avatar
why not just take them off opposed to cutting them? just curious
Old Jul 14, 2008 | 09:04 AM
FlipCpt45's Avatar
Shi.. my friend that was going to install it, which has 2 cars an Evo 9 which is lowered, and a Civic that is EXTREMELY LOW. Told me that i don't even need bump stops! ?
Old Jul 14, 2008 | 09:24 AM
n3985's Avatar
大陆弟弟
How much did you cut? I only cut the top "donut" off
Old Jul 14, 2008 | 09:38 AM
maximadave's Avatar
what ever Eibach recommended.
Old Jul 14, 2008 | 10:46 AM
Norkoastal's Avatar
Would anyone recommend to cut the bumstops on a H&R front drop ??? I dont see much height difference between the two, and with the H&R it would squish more I would think. I haven't crashed (noticeably bottomed out) since ive installed, but I am most likely going for Illumina's all around so I dont want additional expenses cutting these bumstops out after all is said and done.
Old Jul 14, 2008 | 11:00 AM
sublime258's Avatar
I put my Illuminas and H&Rs on about 2 months ago and didn't cut my bumpstops. I have only bottomed out once, and it was a REALLY bad hole in the road. I don't think it's necessary for H&R springs.
Old Jul 14, 2008 | 01:14 PM
Lawtown's Avatar
What about 4th gen Progress springs (front only) on a 5.5 gen? Would I have to cut the bumpstops?
Old Jul 15, 2008 | 08:50 AM
Mattlikespeoples's Avatar
i've got the tien s-techs and i bottom out but I think my stuts need to be replaced because it's a pretty bouncy ride on even slightly rough roads
Old Jul 15, 2008 | 12:10 PM
rocketsled's Avatar
03 6spd. Did not cut bumbstops. Eibachs and Illuminas. I drive on really rough country roads. No bottoming out. yet. Think i would rather have Steel on rubber contact rather than steel on steel contact. The thought of bottoming out without bumpstops isn't a pretty one...
Old Jul 15, 2008 | 12:40 PM
n3985's Avatar
大陆弟弟
Rough country roads are no match for NJ/NYC pot holes and random 3" bumps by toll booths
Old Jul 15, 2008 | 06:37 PM
metalpiotr's Avatar
03 Maxima, 6spd
I have Eibachs with Illuminas and I cut mine only 10 mm. In the front I got Strut Mate (by Monroe) dust boots/bump stops and in the rear I have KYB. With both, cutting them any more than 10mm of the top, seemed like there would have been no way for them to stay up at the top of the strut rod (the bump stop would slide down). I don't see a way of doing it at all with the stock ones.
I am very curious how people have done it and managed to keep the bump stop from sliding down.
I honestly don't know if I am bottoming out or not. Not sure what it would sound like. I also hear all sorts of noises on bumps and sometimes the dash board is rattled on big ones, but I think that could be because I didn't replace my strut mounts in the front (big mistake) and it makes sense that a stiffer suspension would cause more noise. I also found that when I softened down my illuminas to 2 (just experimenting), I seemed like I didn't hear any of those noises (but then again, I didn't keep it at that setting for too long.. quickly went back to 5/5).
Old Jul 15, 2008 | 06:44 PM
VQP0WER's Avatar
I have Eibachs and have not cut my bumpstops and never had any issues bottoming out, and the roads here in Oklahoma suck.......
Old Jul 15, 2008 | 07:41 PM
irish44j's Avatar
retired moderator
n00b////
Old Jul 15, 2008 | 07:55 PM
maxspeed96CT's Avatar
The original VQ...
I had eibach and tein s-tech on my 02 max and never had to cut any bump stops. Nice smooth ride
My friend on the other hand has a 03 i35 and on s-techs his car sounded like it was going to break in half over bumps..
I know the basicly the same car but u never know.....
Old Jul 16, 2008 | 06:16 AM
dubious's Avatar
I have eibachs - previously on hp's without cutting bumpstops. Going over bumps/potholes, etc. sounded like the car was going to fall apart.
After the wife refused to drive my car for a couple years, I Swapped out shocks to illuminas (on 3 all around) a couple of weekends ago. I cut the front bumpstops, but not the back. Overall ride is better - but holes/bumps are still jarring (unavoidable commuting to downtown ATL daily).. Not sure if I'm hitting bumpstops or if it's just the stiffer springs.
Old Jul 16, 2008 | 06:41 AM
hi-tek22's Avatar
same here, i bottom out on really bad bumps, mainly because i like driving curb lanes, but this is only with my passenger side FRONT, ive got my struts set to 4 up front and 5 in the rear.....but I didnt cut mine at all
shilov
Feb 19, 2024 09:40 PM
pears
Sep 18, 2015 05:25 AM
blakkheartt12
Sep 17, 2015 08:11 AM
crazyespn
Sep 3, 2015 01:30 PM
