MOOG VS OEM Front Sway Bar End Links
Old Sep 28, 2010 | 10:16 PM
  #81
BLACKKILA.GTR's Avatar
SO wat are the real advantages?? of replacing these end links?
Old Oct 25, 2010 | 08:07 AM
  #82
ghostrider17's Avatar
Nissan Sway Bar Endlinks < MOOG
Gonna bump this....
I just replaced my OEM end links with only 20k miles -- they were shot.
Looking back to when my car was new -- I've ALWAYS had trouble with the rattling front end....so I'd say the original endlinks failed a LONG-LONG time ago as well.
This time, I had replacement links from the LCPKit, so those went in -- but from now on, it's MOOG's for me.
STAY AWAY from the OEM endlinks. You've been warned!
gr
Old Nov 26, 2011 | 11:47 PM
  #83
GreekMaxima's Avatar
can someone post how's to??
Old Dec 7, 2011 | 06:58 AM
  #84
arkangelgabriel's Avatar
i know this post is kinda old but helped me a lot with my diagnostic. Gonna order tie rod ends and FSBL soon. ill get Moog
Old Dec 7, 2011 | 08:06 AM
  #85
you wont regret man!!!!!
i didnt know that little thing will make such a difference on my cars ride, feels like new.... seriously im so impressive!!! and is cheap... $18 each!
Old Dec 7, 2011 | 10:10 AM
  #86
markjc's Avatar
I would go with Moog too. I work at a shop and we get a lot of suspension work. We end up doing the same job over again in the not so distant future when we use suspension components other than higher quality stuff, like Moog.
Benefits of replacing worn sway links with new ones are elimination of any existing noise or clunking and in particular, better body control during turns.
Old Dec 7, 2011 | 03:59 PM
  #87
Thx! Yeah i get clunking noise when going over bumps (fsbel) and clear vibration from front end when braking. after long research and diagnostic and trials figured its tie rods. Ordered inners outters fsbl and fsb bushing moog
Old Mar 21, 2013 | 10:05 AM
  #88
DIMS's Avatar
Originally Posted by vastmax
correct me if i'm wrong, but the SE is 23mm, the GLE and GXE are 22mm.
uh oh i ordered the 23mm for my gle does that mean this wouldn't work?
Old Mar 21, 2013 | 07:52 PM
  #89
03GLEmaxima's Avatar
23 wont work. I made the same mistake.
Old Mar 23, 2013 | 04:19 PM
  #90
cmd26's Avatar
23mm se 22mm gle
Old Mar 24, 2013 | 07:07 PM
  #91
bennuss's Avatar
Do I have to pump these with grease or do they come full greased? And if yes what grease is recommended and how do I grease them?
Old Mar 24, 2013 | 08:00 PM
  #92
My energy suspension bushings came with a pack of grease. Just glop the grease in the hole and lube it up good before you install.
Old Apr 6, 2013 | 05:43 PM
  #93
HerBlue2kSE's Avatar
Originally Posted by boondoxmax
I installed those and new swaybar bushing on friday and man the car feels like it did when it was new. Not a sound over bumps. All you hear is the tires over bumps. Man my bushing and links were shot to hell. I used Moog end links but OEM bushings cause I was afraid that the ES bushing would transmit to much impact harshness into the car
I know this is an old thread but my experience is the same. The car's handling is tight, steering response is more precise, and the clunks in the front end that my wife has complained about for 5 years are gone. I got the Moog end links and sway bar bushings from Rockauto for $35 shipped to my door. Well worth the 1 hour of time it took to do the swap. I put anti-seize on the bolts when I reassembled it too.
Old Apr 6, 2013 | 06:03 PM
  #94
bennuss's Avatar
Any reason to get the es bushings over the moog bushings which on rockauto are 6 dollars instead of 20?
Also is the sway bar link what is called in the nissan manual connector? I could not find the term anywhere in the manual. Also is the transverse link he same as the control arm ? another term that i could not find in the manual.
Is it hard to change the control arm bushings? Mine seem to be shot.
Old Apr 6, 2013 | 06:22 PM
  #95
I believe the ES bushings are poly and the Moog bushings from Rockauto are rubber like the factory pieces. The poly bushings firm things up but will also transmit more vibration into the steering wheel and the body of the car. Can't address the other questions that you have as I have not messed with those. I am pretty sure the control arm bushings need to be pressed in with a hydraulic press and need to be removed from the car to do the install.
Old Apr 6, 2013 | 07:02 PM
  #96
bennuss's Avatar
Would it be cheaper to buy new control arms with i presume have the bushings already pressed in than to pay a shop to change the bushings?
Is there a reason why rockauto is half the price on the sway bar links? Are they different?
Old Apr 6, 2013 | 07:03 PM
  #97
cjandura's Avatar
Moog end links and es everything else just look in the Dj suspension thread for info on installing the moogs
Old Apr 7, 2013 | 02:18 AM
  #98
slo-ryde's Avatar
In the Maxima parts catalog the sway bar links are referred to as "rod assembly-connecting, stabilizer" and yes, the transverse link is what most would call the lower control arm. When you purchase the transverse link from Nissan it has the bushings installed and a new lower ball joint.
There's a lot of discussion on this forum about Moog being better than OEM, but with 240,000 miles on my stock '02 GLE it's my opinion the OEM stuff is plenty strong enough. The only front suspension components I've replaced are the struts, strut mounts, strut boots, and the passenger side inner tie rod. Some feel having the ability to grease the front suspension points is a bonus. After 240,000 miles on stock suspension parts that have never been greased I question just how important this "feature" of Moog parts really is.
The ES poly bushings are stiffer than OEM, expect tighter and faster handling but be prepared to loose some ride comfort in the process.
Old Mar 11, 2014 | 01:35 PM
  #99
roccobonez's Avatar
link kits
I have a 2002 nissan maxima SE. The car has lowering Eibac springs and the link kits keep breaking. Are there special performance kits you can recommend, or should i just use aftermarket parts?
Old Mar 14, 2014 | 08:12 PM
  #100
SoulEater's Avatar
don't buy moog. i used to love them. but not anymore. they are junk now, IMO.
not really related to maxima, but i used moog on my honda odyssey and crv. the rubber didn't last for 2 years. search and search, i found another brand proforged. i installed these 3 years ago, but they still work like the day i just put it on. they 1 million miles warranty.
Old Mar 15, 2014 | 06:36 AM
  #101
foodmanry's Avatar
Da Roller Coaster!
I went with OEM, fairly inexpensive, and they have lasted 5 years so far....
Old Mar 15, 2014 | 06:47 AM
  #102
max ride 41's Avatar
moog from 2 years ago and no issues. if your cars lowered then expect front end issues like worn ball joints, links, and other problems. it's just part of the lowering game.
Old Mar 15, 2014 | 10:56 PM
  #103
benb's Avatar
Just replaced with Moog end links and bushings, no more clunks, good to know I can expect two years out of the repair. The ride is super quiet now, and handles great, the OEM parts were thrashed, had to saw the original bolts off too.
Old Apr 2, 2014 | 08:27 PM
  #104
SAK74's Avatar
Moog is owned by AutoZone
Old Apr 5, 2014 | 04:01 PM
  #105
Lontar1's Avatar
Puerto Rico-Maxima Lover
I just replaced today my tie rods.. 1 year of use, MOOG crap, and replaced them with more MOOG crap, easy job.... but definitely they are crap. Or maybe the street where I moved to are crap...? Hummmmm LOL
Old Aug 7, 2016 | 11:39 AM
  #106
Maxboy23's Avatar
Does anyone have pictures of the sway bar bushing i just ordered a pair and trying to locate it on the car thanks
Old Aug 7, 2016 | 12:11 PM
  #107
Child_uv_KoRn's Avatar
Bad *** Newb
Better off getting the 15 dollar ones off ebay. They come with grease zerts and I've put them on multiple cars with no issue. Definitely last longer than name brand parts.
Old Aug 7, 2016 | 12:18 PM
  #108
Maxboy23's Avatar
Whats the name of them and Do you suggest oem sway bar bushings or pu looking for more comfort i hear the pubwill give better handling but harsher ride
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
