Buttons not lighting up.
Old Sep 8, 2008 | 09:44 AM
jattdemax's Avatar
The lights in the buttons for the heating/AC are all not working. It started off with one light, and now all the buttons are not lighting up. I haven't started taking anything apart yet, thought I ask to see if this is a common problem. Any help is appreciated. Thanks.
Old Sep 8, 2008 | 10:48 AM
mist max2000's Avatar
does the AC/HEAT and blower whatnot still work? if not check a fuse..if so.. sorry SOL for my helping abilities lol ..i love the color of ur car btw..
Old Sep 8, 2008 | 11:21 AM
jasonmax's Avatar
I think you would get idea from reading this thread.
http://forums.maxima.org/5th-generat...controler.html
Old Sep 8, 2008 | 12:31 PM
jattdemax's Avatar
Yea. everything still works, just the button don't light up. And the color is definitely unique. glad you like it!
Thanks for the link. very helpful. I think I might start by checking my fuses, and work my way for there.
Old Sep 8, 2008 | 01:32 PM
wyche89's Avatar
do you have any LEDs or aftermarket HID bulbs in your car? if the fuses check out, try switching the bulbs temporarily.. i had the same issue on 2 maximas, and switching to regular bulbs solved the problem
Old Sep 8, 2008 | 02:03 PM
jattdemax's Avatar
All my bulbs are stock, no LED mods. They may just be blown.
Old Sep 8, 2008 | 03:40 PM
jasonmax's Avatar
if it's just the lights, it's the bulbs.
Old Sep 8, 2008 | 05:35 PM
DrunkieTheBear's Avatar
Turbo'd Saab
time to mod it with LEDs....
while your at it, make the display for the AC and clock white, its better then that green.
Just go to a party supply store and get dark red celophane, its like $2 and cut a small piece out, lick it and stick it on the screen.
Old Sep 8, 2008 | 07:59 PM
jattdemax's Avatar
Im not too knowledgeable is all these LED mods. It's not as easy as just replacing the bulbs with leds?
Old Sep 8, 2008 | 08:17 PM
Turbo'd Saab
actually it is, you can get the 3mm LEDs on ebay of any color you want with the resistor you need. Solder the led to the resistor, and then I fit the led to the bulb holder like the bulb was, it worked just fine.
Old Sep 8, 2008 | 10:38 PM
jattdemax's Avatar
sounds good. I'll try that. Thanks
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
coasterswim
Sep 2, 2015 07:43 AM
A32goldylocks
Sep 2, 2015 06:39 AM
