Why would my sunroof tilt up on its own?
Old Oct 5, 2008 | 09:39 PM
Scottwax's Avatar
That's Mr. Detail to you
2nd time this weekend. Start my car in the evening, get a couple miles down the road and I can hear the sound of my sunroof tilting up. Hit the button, close it and it stays closed.
Old Oct 5, 2008 | 10:51 PM
Czerkas's Avatar
button stuck?
Old Oct 6, 2008 | 06:32 AM
robbiem's Avatar
that happened to me a couple times a month or so ago. it hasn't happened since.
Old Oct 6, 2008 | 07:04 AM
Scottwax's Avatar
Maybe my car is haunted by a fresh air loving ghost?
Old Oct 6, 2008 | 07:54 AM
HotshotVQ35's Avatar
i was gonna say the car is possessed!
Old Oct 6, 2008 | 09:10 AM
Feldman's Avatar
probably a switch issue or the devil... either way good luck!
Old Oct 6, 2008 | 09:12 AM
IHAVEA2KMAXIMA's Avatar
i would just get a new max if i were you lol
Old Oct 6, 2008 | 11:16 AM
fuctkeen's Avatar
it probably has something to do with the buttons. maybe it's the wind or something. Sometimes, my radio turns on by itself.
Old Oct 6, 2008 | 11:32 AM
SoulEater's Avatar
Holy crap, that scare me. if i was you guys, i would ask priest or monk to do a ritual things. lol j/k
Old Oct 6, 2008 | 12:43 PM
pikers's Avatar
You're not alone. My roof does this too. Apparently there are issues with the switches. It isn't a big deal; I just double-check it before going in if I think it might rain.
Old Oct 6, 2008 | 05:13 PM
DjCalvin's Avatar
2002-2003
2000-2001
Quick and easy fix - $40
Old Oct 6, 2008 | 07:37 PM
MetaOrbit's Avatar
Got Projectors?
Mine has done it before. I just do the reset procedure and it goes away for a year or more before it comes back.
Old Oct 6, 2008 | 07:43 PM
The Hulio's Avatar
Mine does this too, except it doesn't tilt up, it fully opens. Scares the crap out of me every time. I close it, and it doesn't happen again for months... sometimes years. I thought perhaps water was in there somewhere causing a short or something...
Old Oct 6, 2008 | 08:23 PM
Scottwax's Avatar
Today was the first rain we've had in nearly 3 weeks and I use a rinseless wash (Optimum No Rinse) so I only use a gallon of water to wash it so I am pretty sure water isn't the problem.
I did do the reset procedure yesterday when it happened the second time. Hopefully that fixes it at least for a while.
Old Oct 6, 2008 | 11:07 PM
Norkoastal's Avatar
Someone from OT rigged your sunroof to **** you off SW... lol
Old Oct 7, 2008 | 07:57 AM
Deckdout2's Avatar
Play with my balls
This has been an issue that goes along with the sunroof not functioning properly. There is a gray relay under the driver side dash that you can just pull and wait a few seconds and plug it back it. It's the relay that is acting up and not the switch. Sometimes as well, when you go to open or close the sunroof, nothing happens. Or when you press the tilt switch it starts to open vs actually tilt. All is relay related, and pulling it and plugging it back in seems to do the trick as it's also a reset procedure. I have had a thread on this in the past, but it's so old that it could be on our old server and lost. Maybe someone will be able to find it at some point.
Old Oct 7, 2008 | 05:21 PM
Scottwax's Avatar
Interesting. Relay has a mind of its own, eh? Thanks for the suggestion.
Old Oct 8, 2008 | 05:33 AM
russianguy's Avatar
i m gonna try the relay reset , i recently had some work done to my car and it seems that my sunroof doesnt open anymore.
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
