vq30det in 2000 max
Old Oct 14, 2008 | 07:02 PM
Max00se's Avatar
vq30det in 2000 max
Is it a possible swap?
Old Oct 14, 2008 | 07:11 PM
DrunkieTheBear's Avatar
Turbo'd Saab
Your answer lies in searching...
http://forums.maxima.org/general-max...8-vq30det.html
BTW how can you start a thread if this is your first post?
Old Oct 14, 2008 | 07:12 PM
Turbo'd Saab
btw good luck finding one for anywhere near a responable price.
and why, you can just turbo your current engine and produce way more power then that thing.
Old Oct 14, 2008 | 07:13 PM
Max00se's Avatar
i have no idea i havnt really been a member long...i just put this on sorry ha...but i found one for 999...is the motor transversly mounted or no...like will it go in the max?
Old Oct 14, 2008 | 07:14 PM
Feldman's Avatar
anything is possible with enough money, and patience.
I think the vq30det was setup for rwd or awd which means you would have to either find a way to make it fwd or make your max rwd or awd which would be awesome!
Probably not the most economical mod you could do.
how about getting a super charger or turbo setup for your existing engine. I bet you could swap out the internals of the det if you wanted to and you could create your very own vq30det
Old Oct 14, 2008 | 07:18 PM
Max00se's Avatar
well originally i wanted to turbo it..but i cant find manifolds for my car. i wanted to get one fabricated for me but noone around here wants to make me one..will the manifold from a vq30det go on my car. if so i could possibly take the pistons and the heads from it as well?
Old Oct 14, 2008 | 07:20 PM
Turbo'd Saab
buy the motor and sell the parts on here, you'll make all the money back plus some LOL
If you buy the motor you have to strip your current engine to block, and use the bottom end internals, then you can either use the heads from that engine or your engine, but I would use your IM.
Old Oct 14, 2008 | 07:22 PM
Turbo'd Saab
As a side note some guys will sell there turbo kits used with all the manifolds and such made already. But you need to gather the parts and find a real performance shop that can build custom setups if your not gonna do it.
Max00se's Avatar
well of course i wanna keep that variable intake its sweet ha...but would the manifold from that engine go on my block or would there be fitment issues?
Old Oct 14, 2008 | 07:25 PM
Turbo'd Saab
those heads should be the same as you current engine, so your current LIM should bolt up and then of course you can use the UIM. the exhaust manifolds should also fit, the bolt patterns should all be the same.
and expect this thread to be locked.
Old Oct 14, 2008 | 07:26 PM
Max00se's Avatar
well i know this..i want a manifold built i dont want the trouble of building it....then once i do that i was going to relocate teh battery so the turbo can sit where the battery sits have the cold side go over the head with teh bov...down to the front mount the up in then have the custom 3in dp...and exhaust...
Old Oct 14, 2008 | 07:27 PM
Max00se's Avatar
ok that is good to know...now the only problem is...finding them ha
Old Oct 14, 2008 | 07:29 PM
Turbo'd Saab
Well, I suggest taking some time and looking at the turbo/supercharged section, a number of different setups can be found in there and you can get some ideas on all the details to doing all of that, a number of guys have done the exact setup you have described.
Old Oct 14, 2008 | 07:31 PM
Max00se's Avatar
ok cool i will look around thankss...
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
RinconI30
Jun 11, 2016 08:25 PM
homewrecker
Sep 23, 2015 03:41 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
