ES motor mount for auto's
Old Dec 27, 2008 | 10:10 AM
knight_yyz's Avatar
Toolie
ES motor mount modification for auto's
Just thought I'd throw this out there for people who have automatics and want to put both front and rear ES motor mounts on the car. Take the front off and make a spacer from aluminum, then press it into the bracket, then press in the mount. I'd make them for a fee but I'm out of work for about a month and a half and don't have access to a lathe...
Old Dec 27, 2008 | 10:39 AM
VQP0WER's Avatar
What type of aluminum?
Old Dec 27, 2008 | 10:47 AM
knight_yyz's Avatar
Toolie
t-6061, Although it wouldn't really matter, as long as it is in the bracket tight, and the bushing is tight. I used aluminum as it is easier to machine, could use steel if you want.
Old Dec 27, 2008 | 01:51 PM
Torgus's Avatar
interesting...
Old Dec 27, 2008 | 05:24 PM
diverdown3's Avatar
You (OP) wouldn't happen to have written the inside diameter (ID) and outside diameter (OD) and sleeve width down would you? With that, one could go to a local machine shop.
Old Dec 27, 2008 | 11:25 PM
knight_yyz's Avatar
Toolie
I wrote it down, but I didn't bring it home with me.
Old Dec 28, 2008 | 12:56 AM
AceofSpds's Avatar
wat
I guess ill add this to someone who might find this while searching this topic, but You can also just replace the whole thing with an MT car's mount.
Old Dec 28, 2008 | 01:01 AM
JonBlz's Avatar
a.k.a. STuNtMAN
you wont need the aluminum piece if you dont have the sensor on the front mount....if you have the sensor in the front mount then you need this
Old Dec 28, 2008 | 03:24 AM
CMax03's Avatar
May the Good vibrations begin....
Old Dec 28, 2008 | 03:35 AM
JonBlz's Avatar
a.k.a. STuNtMAN
^vibration only happens for a few days then after it feels normal again i dont regret it EVER
Old Dec 28, 2008 | 05:41 AM
maxboy325's Avatar
I thought I would have to say it.
Old Dec 28, 2008 | 12:02 PM
CMax03's Avatar
How much better is your launch out the hole under heavy throttle? The Good Vibe is a joke by the way. I just used 3M Window Weld on my neice's Toyota Tercel (4 ea) motor/trans mounts and it was little idle vibration at the beginning but I guess it's good now, cause all she doing is piling up the miles.
Old Dec 31, 2008 | 03:47 AM
secondtonone317's Avatar
nycnissans
I have all my mounts polyed and it feels great
Old Dec 31, 2008 | 04:43 AM
Peanuthead's Avatar
How long did it take the poly to fully cure/dry and does it feel like to you that they had to break in?
Old Dec 31, 2008 | 07:13 AM
knight_yyz's Avatar
Toolie
This is true, but the front mounts are getting harder to find. And this is a cheaper option as I found most wreckers will not sell you the one mount, they want to sell the whole crossmember for 100 + dollars.
Old Feb 26, 2009 | 05:40 PM
knight_yyz's Avatar
Toolie
someone was asking me the dimensions for the ring. Off the top of my head the OD is just over 100mm. But I also noticed that after pushing the crappy mount out of the bracket that, the hole was not perfectly round. So I measured across the small diameter, then measured across the large, averaged it out and added about .010". Then press fit it in on the hydraulic press.
Old Feb 26, 2009 | 06:29 PM
maxximaa's Avatar
im lost, what does this spacer/ring do? i have AT
Old Feb 26, 2009 | 06:43 PM
knight_yyz's Avatar
Toolie
auto's have a larger front mount than the rear mount, so if you want to use ES mounts you can only put one on the back mount, or buy a 5 speed front mount which are getting harder to some by. or you can do what I did for a friend of mine and put this spacer in
Old Feb 27, 2009 | 08:00 AM
maxximaa's Avatar
do i need anything if i wanna go with new OEM mount?
Old Feb 27, 2009 | 10:19 AM
knight_yyz's Avatar
Toolie
no
Old Feb 27, 2009 | 11:59 AM
ShIft_uR FacE's Avatar
Is there a write-up anywhere on how to change out motor mounts? Also, i suspect i have a malfunctioning motor mount as i have been having excess vibration and a very hard jolt from the motor when i put the car in drive when cold..any way to check which one is messed up? I have access to a cnc machine and might be able to make that aluminum ring myself on spare time.
Old Feb 27, 2009 | 12:44 PM
Kevlo911's Avatar
Kevlo for President
What happens when it gets hot and expands at a different rate than the steel?
Old Feb 27, 2009 | 12:46 PM
CMax03's Avatar
So what happens to the engine mount connect after installing this(on the auto)?
Old Feb 27, 2009 | 12:48 PM
Kevlo911's Avatar
Kevlo for President
You put in the ES bushings
AaronL
Sep 23, 2015 03:34 PM
vball_max
Sep 17, 2015 10:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
