Fitting 2002 cali-spec B-pipe (Cattman) on 2000 Fed-Spec
Old Jan 9, 2009 | 12:54 PM
Progress's Avatar
It's business time.
Referencing this thread:
http://forums.maxima.org/5th-generat...ipes-same.html
Also referencing these diagrams:
http://www.courtesyparts.com/maxima-...1981_1982.html
My resonator took some damage and has a leak causing the exhaust to drone. I purchased a used Cattman B-pipe from an .org member with an '02 Cali-spec car. It is in transit.
I did not do my research.
What kind of problems will I have if I try to install this B-pipe on my car? I'm of the understanding that I could try welding the O2 censor bung onto the aftermarket B-pipe. Is it worth the troubles, though?
2000 Fed-spec. My exhaust is stock otherwise.
Old Jan 9, 2009 | 12:58 PM
Puppetmaster's Avatar
I think you'll be fine. Just follow the exhaust diagrams and weld the bung behind the main cat.
Old Jan 9, 2009 | 03:28 PM
Deckdout2's Avatar
Play with my balls
Sup Pro...Pup is correct.
Old Jan 10, 2009 | 12:04 PM
Progress's Avatar
It's business time.
What's up guys. Thanks. So any trustworthy shop should be able to do this, you think?
Old Jan 10, 2009 | 12:33 PM
Feldman's Avatar
i wouldnt just take it to any shop but a muffler shop should know what they are doing.
Old Jan 10, 2009 | 01:03 PM
Progress's Avatar
It's business time.
I have a shop in mind that has done exhaust work for me in the past. I'm pretty confident in their competence.
Old Jan 13, 2009 | 10:12 AM
Progress's Avatar
It's business time.
Quick questions: does a hole need to be drilled in for the O2 sensor to be placed? if so, is this hole drilled in the b-pipe or in the cat or some place else? Or is there a piece that is welded in between the b-pipe and the cat with the O2 sensor?
Old Jan 13, 2009 | 10:32 AM
If you have a 5.5 Gen Cattman B, then yes. Just weld it in close after the cat on the b-pipe, that should suffice.
Here's what the stock placement looked like:
Old Jan 13, 2009 | 08:17 PM
Progress's Avatar
It's business time.
Okay, thanks. Do I need to buy a bung to weld in to the hole for the b-pipe or should I just be able to swap the one already in the car?
Old Jan 14, 2009 | 06:23 AM
I would think an O2 bung is a pretty standard piece for most exhaust shops, so check with those guys.
Old Jan 14, 2009 | 08:31 AM
Progress's Avatar
It's business time.
Okay, cool.
Old Jan 14, 2009 | 08:44 AM
CMax03's Avatar
18mm O2 bung, drill hole out to 3/4" with unibit! Take to welder or muffler shop
Old Jan 17, 2009 | 05:25 PM
Progress's Avatar
It's business time.
Okay, cool. So something like this:
http://cgi.ebay.com/ebaymotors/O2-Ox...QQcmdZViewItem
Also, I had a question about the general exhaust system. I noticed the resonator is sitting pretty low to the ground (likely how it got hit in the first place). I am dropped, but I'm not sure if there is general weakness in the exhaust system causing the resonator to sit exceptionally lower than it should. Granted, I haven't jacked the car up to see if it is sitting lower. But if it is, is there anything I should consider fixing installing a stainless steel mid-pipe knowing it's heavier. I don't want to take it to the shop and then realize I need to get new parts or something (hangers/brackets).
Old Jan 18, 2009 | 09:12 PM
CMax03's Avatar
Yeah something like that, except make sure it comes with the plug as well!
Mar 12, 2020 12:06 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
GregL65
Sep 7, 2015 10:33 PM
