Weird annoying suspension noise
Old Jan 31, 2009 | 06:43 PM
Ahmad_1290's Avatar
I’ve got this weird suspension noise. It only happens when I turn the wheel all the way, right or left and hit a bump. It’s like a nasty squeak/rub. I am lowered on Progress/ stock struts (I know.. big no no but its temporary). Any ideas of what it could be.
Old Jan 31, 2009 | 10:39 PM
Ahmad_1290's Avatar
anyone?
Old Jan 31, 2009 | 11:30 PM
zero2sixtyZ's Avatar
You embarrass me.
Strut mount bearings?
Old Feb 1, 2009 | 06:49 AM
Puppetmaster's Avatar
Steering bump stop perhaps?
http://forums.maxima.org/5th-generat...noise-wtf.html
http://forums.maxima.org/5th-generat...l-bearing.html
Old Feb 1, 2009 | 07:11 AM
Ahmad_1290's Avatar
Anyone have anypics of this part? or pics of where it is on the car. All the link inside those links are dead.
Old Feb 1, 2009 | 07:54 AM
Links worked for me...
http://arslaan.myweb.uga.edu/bumpstop.jpg
http://forums.maxima.org/3672256-post24.html
Old Feb 1, 2009 | 09:47 AM
Love_00_Max's Avatar
The strut mounts if they come apart from the rubber, there is this annoying squeaking sound. I would confirm by turning the steering colmn all the way doing steering locks while the vehicle is parked.
I had a strut mount fail a few weeks ago and had the same issue that you detailed in the thread. BTW if the mount came off the rubber, the only way to remove the spinning hat bolt is using an impact wrench. Good luck.
Old Feb 7, 2009 | 05:14 PM
Ahmad_1290's Avatar
So it is the steering bump stops, Is there a substitution for the part? instead of going to the dealer n buying both.
Old Feb 7, 2009 | 06:50 PM
Why not? They are like a buck fifty each according to this guy:
http://forums.maxima.org/3665885-post21.html
Old Feb 7, 2009 | 07:52 PM
Ahmad_1290's Avatar
oh dang didn't know that. I guess I'll call Nissan Monday and see if they have it in stock
Old Feb 7, 2009 | 08:46 PM
Judas's Avatar
My guess is that it's your wheel bearing and/or hub. I had the same issue on my 02.
The TSB doesn't apply so, I wouldn't expect any help from the Stealership.
Just my .02.
Old Feb 7, 2009 | 09:26 PM
Ahmad_1290's Avatar
I already figured out the problem as stated above. Steering bump stops
Old Feb 7, 2009 | 09:40 PM
yazz's Avatar
Have a look at your CV boots and axles too?
Old Feb 8, 2009 | 06:40 AM
The OP just posted directly before you and even before that a few posts up that he's already found the problem to be the steering bump stops.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
mpbclutch33
Dec 26, 2015 11:11 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
