cel P0174
Old Mar 27, 2009 | 07:17 AM
williamgd2's Avatar
cel P0174
2000 se with cal emmissions .I have a cel PO174 I got it shortly after installing a Injen cold air intake,So far I have cleaned the mafs replaced 2 of the 4 oxegen sensors.My guess and just a guess is I mixed up some vacuum lines.Is there any where I can get a detailed map of the vacuum line route? Or do any of you guys have a idea of what else it could be?Any and all help is greatly apprieciated.
Old Mar 27, 2009 | 08:01 AM
pmohr's Avatar
No more Maximas...
Old Mar 27, 2009 | 08:12 AM
2damax's Avatar
If all the hoses match up (which they should, the intake isn't to hard to install) then consider the MAF. when you were putting in the intake did you drop the maf. or shake it a lot? Even though you cleaned it, it could still be damaged. Has the MAF ever been replaced on this car before? Also make sure you secured the intake on with no leaks and that everything is tight. Air leak in the intake system could cause this i think.
Old Mar 27, 2009 | 08:49 AM
williamgd2's Avatar
Thank you Guys,That is a great vaccum diagram.Everything on the intake is tight.The Mafs could be bad,I just ordered 1 from 1 of our member dealer,s I have never replaced it but have only had the car since November 08 I will double check the vacuum lines now that I have the diagram.
Old Mar 27, 2009 | 08:52 AM
pmohr's Avatar
No more Maximas...
Who did you order from? You can get a new MAF from Dave B for ~$80.
Old Mar 27, 2009 | 09:32 AM
williamgd2's Avatar
That is who I ordered the MAFs from Dave B Great price.I did have some vacuum lines mixed up and for now the light is off.If it comes back on I will replace the MAFs.If it stays off then I will have a spare sensor.But I am someone who likes to have some common spare parts on hand.Thank you Guys for your help This place is great to be a part of.
Old Mar 28, 2009 | 11:13 PM
Judas's Avatar
I had the same code right after I cleaned and "Re-oiled" my Stillen Intake. Key word there is "re-oiled"... Some of the filter oil must have gotten onto the MAF Sensor because it gave me the P0174 Code. Instead of buying a whole new MAF, I cleaned it. I haven't had the code since. The cleaner worked great! and it was wicked easy.
just my .02.
Old Apr 16, 2009 | 10:09 AM
williamgd2's Avatar
Still same problem replaced 2 02 sensors,Replaced Mafs and had it programed at the dealer,Made sure all connections on injen intake were tight and filter was clean.I am thinking maybe a small exhaust leak?I was told the code ment bank 2 too lean.Anyone have any ideas?
Old Apr 16, 2009 | 04:18 PM
williamgd2's Avatar
I thinkThat it is the intake manifold gasket,I hear loud hissing on back of intake and I checked all the vacuum lines.Idles and runs fine exept for the code.
Old Oct 27, 2014 | 09:05 PM
Kretzmech's Avatar
Can anyone tell me what that hose off the Swirl Control Valve Actuator is supposed to be connected to? Is it supposed to connect to vacuum or just stay open and unconnected, like shown? Thanks.
Old Oct 28, 2014 | 09:36 AM
00Lightsout's Avatar
it should be connected to a metal connection directly above it
Old Oct 28, 2014 | 03:16 PM
Kretzmech's Avatar
I don't have a metal connection. Do you know if its supposed to connect to vacuum or possibly air box?
Old Oct 28, 2014 | 08:20 PM
it's supposed to connect to a vacuum line. if it doesn't open and close the baffles, your air/fuel ratio will be wrong under moderate to heavy acceleration.
Old Oct 28, 2014 | 08:38 PM
Kretzmech's Avatar
Cool, thanks good to know! I just connected it to a vac line.
Old Oct 29, 2014 | 09:41 AM
it needs to be connected to a specific vacuum line because it's operated by the intake vacuum pressure for the variable air controls and swirl-control-valve/control-vacuum-check-switch. the vacuum line should be a small metal line that runs parallel above the fuel rail about 2" with a T off between cylinders 4 & 6.
Old Sep 24, 2025 | 01:42 AM
I35GEEK's Avatar
I also got a P0174 error with engine idling rough. It got progressively worse to the point where the car almost stalls. I replaced the MAF and housing. My car runs like new - no issues now.
Tony Baron
Oct 19, 2020 04:37 PM
maxima dude
Jan 24, 2011 08:14 AM
BLK2BLU
Sep 19, 2006 09:06 PM
nismos14
Sep 17, 2003 12:41 AM
