O/D LIGHT FLASHING NORMAL??
Old Apr 7, 2009 | 03:11 PM
JoE'sMaX01's Avatar
hey just did a search and couldnt find anything about it but was wondering if anyone knew what the normal amount of flashes for the O/D light was? is there anyway of knowing what the flashes mean? Usually my O/D light flashed a few times but this time its looking like its flashing excessively more than usual.
Any ideas any codes ? I'm thinking my CAT is no good any way of knowing??
Old Apr 7, 2009 | 07:28 PM
pmohr's Avatar
No more Maximas...
The O/D light will not indicate a problem with your converter, it only shows trans codes.
Use the procedure in the FSM (or just search for it on here) to pull the codes.
The same codes should be available via the CEL as well, so you could just check the codes with an OBD-II code reader.
Old Apr 7, 2009 | 08:07 PM
JoE'sMaX01's Avatar
I'll have to take it to my mechanic but my CEL is not on.
Old Apr 8, 2009 | 04:56 PM
Rico456's Avatar
It may also be the result of low transmission fluids or something of that nature; reasons for saying so I had ran over a down light pole on the highway and damage my transmission pan leaking the entire fluid on the side of the roadway. After a day I started the car after getting it towed to a garage and notice the O/D light flashing replace pan and refill fluid problem solved.
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
intimidator
Sep 5, 2015 07:23 PM
dcardello
Sep 3, 2015 11:44 PM
