Slave Cylinder Install
Old Apr 7, 2009 | 04:50 PM
bigj01AE's Avatar
I'm encountering a problem after installing a new slave cylinder. The pedal will either stay at the top and when pressed it springs to the bottom, almost like a switch there's no in between. I've been bleeding the clutch properly, and after pumping it 50-70 times, it builds up very slight resistance towards the firewall. I can see movement at the slave cylinder but not nearly enough to get the car into gear.
Could there be another problem I'm not seeing? There's plenty of fluid and no leaks in the lines. Could there be a problem with the pressure plate that's not allowing the slave cylinder rod to fully extend? Or is there adjustment on the pedal itself that could help? Thanks for any insight.
Old Apr 7, 2009 | 05:18 PM
Ahmad_1290's Avatar
maybe the clutch master cylinder? Im changing mine this weekend
Old Apr 7, 2009 | 05:24 PM
Kevlo911's Avatar
Kevlo for President
Did you bleed the system?
Old Apr 7, 2009 | 09:35 PM
bigj01AE's Avatar
Yeah I've been bleeding the system but I only get minimal clutch pressure at the firewall. It's like I only so much out of the bleeding. How long does bleeding normally take?
Old Aug 28, 2012 | 05:16 PM
djstocks's Avatar
Mine does that only like on the hottest day of the year for like 3 years now ive replaced the cluch but no change
Old Aug 29, 2012 | 01:10 PM
CADguy's Avatar
The first time I bled it when I did the master cylinder, I messed with it for HOURS. Went to Harbor Freight, and got a pressurized bleeder that you hook up to a compressor. It was done in like 15 minutes after that. Best 25 bucks Ive ever spent.
Also, I had to replace the slave right after I replaced the master, so you may as well go ahead and do both while youre in there.
Old Aug 29, 2012 | 06:45 PM
CaTalyst.X's Avatar
I remember doing this a couple years ago. I had a similar problem. Im trying to remember what Dave B told me.
It was something to the affect of, bleed it as best you can (maybe put a couple cans of DOT 3 through there) and once you tighten the bleeder screw, it builds up pressure pretty quick by pumping the pedal. If I remember right, he said something about a coil line, and thats how it's designed. It doesnt bleed like any other clutch/brake system I have ever bled.
I hope that helps =/. Give Dave B a call if you cant get it going.
MaxLife17
Jun 27, 2019 01:37 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
bbsitum
Sep 11, 2015 04:55 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
