Safc help
Old May 2, 2009 | 01:04 PM
allblackmax96's Avatar
Safc help
hey guys whats going on, i just hooked up my SAFC I and im having a slight problem. it basicly wont rev, its acting like it has a bad maf. i havent changed any settings at all yet (accept making it a 6 cylinder), any suggestions. it is showing voltage from every sensor (tps goes to full voltage). do i need to setup something in the ETC. or something? thanks
Old May 4, 2009 | 06:31 PM
EnervinE's Avatar
i has college
Just an educated guess, but from my research on setup of the VAFC you need to select a MAF type somewhere in the options. That would explain why your car's acting like it has a bad MAF, it's unable to read the signal coming from the SAFC. Any codes?
Old May 4, 2009 | 06:50 PM
99Silvermist SE's Avatar
VAFC/SAFC Install and other info
You need to set the in out and the direction under settings I believe. I'd also be sure to do a reset on it if you havnt already, You wouldnt want to ride around with someone elses maps.
Old May 4, 2009 | 09:17 PM
sorry for the late reply but i figured it out about 5 minutes after i posted. i stupidly didnt pull the ecu lever in all the way and must've had bad contacts for the MAF sensor.
ill post up some dynos after the meet in acouple weeks...
t6378tp
Aug 24, 2015 07:03 AM
ejj
Sep 19, 2003 11:07 PM
Max4Speed
Sep 16, 2003 12:39 PM
xHypex
Jul 15, 2003 07:24 AM
JAY25
Oct 21, 2002 03:15 PM
