a.c still not cool... y??
well i have changed the compressor the condenser and have gotten a leak test, wat else could it be?? ive heard about some sheeet in the bak of the glove box anyone eva did this??
Did u recharge it after?
Leak test shows no leak?
Does compressor kick on?
Check pressure to make sure its not overcharged.
I believe there is an "air con" relay, not 100% sure but check that out also
Is the control working the way its supposed to?
yeah i took it to pep boys and they recharged it
doods at pep boys said no leak present
compressor comes on
i dought they would over charge it. when they checked it it was a lil
under charged
where would that be??
control meaning
compressor comes on
under charged
control meaning
turbonut has a point, a system should be free of non- compressional s before recharging. In other words, It should be evacuated, the drier replaced or restored, and nothing but the refrigerent and oil left in the system.
Op, go out to your car and turn your AC on full blast. After about 5 minutes, feel the low-side hose going into the evaporator (firewall). Is it cold? If so, your system is working up to that point and the expansion valve most likely the culprit. If not cold, then you've got some other problem. Also, try hosing down the condenser.
Also, make sure the shop replaced the accumulator drier when they did the compressor.
BLACKKILA.GTR
05-16-2009 04:32 PM
