Strobes in 2K2 Headlights?!?!?
Old Nov 27, 2001 | 05:07 AM
Deac's Avatar
Sup Fellas,
I have a 2k1 Maxima and I have Whelen Strobes installed in the headlights and in my 2k2 tail-lights! ;o) I have also recently aquired the 2k2 headlights and I want to put my strobes in those too! I noticed though, that you may have to cut a hole in the headlight base to insert the strobes!!! Does anyone w/the 2k2 headligts have strobes installed? Is it worth the risk....I mean, can it be done safely without ruining the lights? I will be installing my 2k2 headlights this weekend so Holla back....
Deac
Old Nov 27, 2001 | 10:29 AM
BigDogJonx's Avatar
Damn you picked the the right type of strobes.
I have the same Whelen strobes with a 6strobe controller. My only problem is how did you install them even on your 2K1 headlight assembly? Cause even there you have to cut into the reflector inside.
I want to install them, they been just chilling here, but at the same time dont want to destroy the assembly trying to install them. Another problem is that the bastard required a 1" hole.
Dixit
Old Nov 27, 2001 | 03:22 PM
Deac's Avatar
I had mine done at a performance shop!
Dixit
I'll post some pics of the strobes in my web-page... but they drilled like a quarter sized hole in each headlight housing, just big enough for the strobe to fit through and rubber cemented the base of the stobe but to the top of the headlight base so it didn't fall all the way through...it looks clean too! I figured it would be the same type of install for the 2k2's but I wanted to be sure...
TallTom
57
Oct 14, 2025 05:16 PM
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
