Just got a 5th gen
Old Aug 9, 2009 | 07:43 PM
Country24's Avatar
Just got a 5th gen
I just got a 2001 maxima about 3 months ago. It has 149k on it and it seems to run pretty good. I drove my friends max and it had a little bit more get up and it was bone stock, so is mine but i just have the k&n air filter. Is there anything that i should do to the car so it runs smoother and has a little bit more pick up with these many miles? Maybe a tune up or new plugs. The previous owner didn't do much so i don't know where to start. Thanks.
Old Aug 9, 2009 | 07:57 PM
e-subliminal-2's Avatar
TUNE UP! oil change, and you might wanna take a look at that k&n, make sure it's not mad dirty and packed with leaves and all kinds of gunk.
gl
Old Aug 9, 2009 | 08:14 PM
dsm=power's Avatar
spark plugs , and maybe check your vias
Old Aug 9, 2009 | 08:20 PM
klemenz's Avatar
reset the ecu. im pretty sure if you drive the car a certain way for a long period of time it catches on and "learns" how you drive. I've heard of guys getting stomped by altimas and minivans because of this
Old Aug 9, 2009 | 08:30 PM
CMax03's Avatar
Check your ignition pulses with a timing light attached to the each coil harness and you can monitor each cylinder for any misses! Run some injector cleaner thru the fuel system and burn off that entire tank of fuel off with a nice highway journey!
Old Aug 9, 2009 | 09:21 PM
The6spdMax's Avatar
remeber to replace fuel filter, pcv valve, and other fluids too
Old Aug 9, 2009 | 09:27 PM
jh15's Avatar
If it is an auto tranny, unplug your engine mounts to prevent your ecu from blowing up and causing downstream IACV failures and the like.
Old Aug 9, 2009 | 09:32 PM
Col Ronson's Avatar
a] oil change
b] coolant flush
c] new air filter or just recharge/clean the k&n
d] new spark plugs
should be about $120 in parts, so not too bad. Check if the tranny has been serviced before. if it has, then just do a drain/fill with some nice mobil 1 syn ATF.
Old Aug 10, 2009 | 10:38 AM
SuperStasiu's Avatar
lol whattt?
Old Aug 10, 2009 | 11:08 AM
Derrick2k2SE's Avatar
Also, clean the MAF. A dirty MAF will rob power. After 150,000 miles it's probably filthy.
Also, make sure your buddys car isn't an 02/03. They have a good bit more power.
Old Aug 11, 2009 | 01:50 AM
BronxSleeperMax187's Avatar
I would start with some brand new plugs,clean the maf sensor, change all fluids with some synthetic fluids, drain and refill antifreeze and tranny, and seafoam vacuum hose + gas tank......Then see the difference
Old Aug 11, 2009 | 02:10 AM
FlipCpt45's Avatar
first time i've heard that one..
Old Aug 19, 2009 | 03:21 AM
blbrizzi1's Avatar
That sounds strange. What are you referring to?
Brent
Old Aug 20, 2009 | 02:13 PM
asenevey's Avatar
You could also check the MAF sensor as mine was killing performance but not throwing any codes. Cleaning didn't do much, but replacing it was night and day on power.
Old Aug 20, 2009 | 02:34 PM
ohitzme's Avatar
His could have been the 5.5 gen they have a 3.5 liter engine with maybe 30 more HP
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
220k+ A32
Sep 23, 2015 03:38 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
