Anyone installed these on 2K2?
Old Nov 28, 2001 | 07:04 AM
Igal's Avatar
Going to place an order with courtesy but would like to see if anyone installed manual AE pedals on 2K2. How difficult is the install? AE door sills should fit, right? Also, did anyone install a courtesy FSTB on a 2K2 yet?
Thanks.
Old Nov 28, 2001 | 08:01 AM
mattattax's Avatar
Re: Anyone installed these on 2K2?
Thanks.
i have the AE door sills on my 2k2, i don't know about the others
Old Nov 28, 2001 | 08:39 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Thanks.
Should be the same, but I'd call Dave B. to see if the pedals are the same part number.
As for the difficulty on installing the AE pedals, they are a PITA until you figure out how.
The EASY part:
The gas pedal/arm is a complete unit and you simple push with your fingers from the back side of the cable until the plastic retaining snap comes through and the pedal is released. Unbolt the two 10mm bolts holding the spring/plate and intstall the new pedal.
The PITA part:
Slip off the brake and clutch(if 5-speed) covers. Slide the top part of the AE cover onto the pedal. Then use a VERY small flat head screw driver to slowly pry the remaining rubber lip around the edges of the pedal. I tried to use grease, heat, and finally I just had to pry to get them on.
I thought the gas pedal was going to be the hard part and the covers were going to be like 5 mins, boy was I mistaken.
Old Nov 28, 2001 | 09:03 AM
Paul D.'s Avatar
Re: Re: Anyone installed these on 2K2?
I've got the AE (chrome) door sills on my '02 as of last week. Interestingly here in Canada they only cost $27 for the front and $23 for the rear for a total of $100 which translated to US dollars is only about $60!
Old Nov 28, 2001 | 09:47 AM
Blackgums100's Avatar
Re: Re: Re: Anyone installed these on 2K2?
Damnit, it's painfully clear that those of us who live in the US are getting ripped off when it comes to Nissan. It's such BS.
Old Nov 28, 2001 | 10:08 AM
Igal's Avatar
Paul D. Where did you buy the door sills for $100?
IceY2K1. I havn't been around too long... who is Dave B.? and how do I contact him to see if the pedals are the same part number.
Thanks again
Old Nov 28, 2001 | 10:35 AM
IceY2K1's Avatar
Thanks again
It's in the sticky "Parts" thread if you need it again.
DaveB's number for OEM parts
800-251-7278.
Old Nov 28, 2001 | 11:07 AM
Paul D.'s Avatar
Thanks again
I got my door sills from the dealer where I bought the car, Walkley Nissan in Ottawa on, you guessed it, Walkley Road. Call Frank in parts @ 613-521-6262 and mention my name. Don't forget to have your interior colour code ready (eg. for the gray leather interior of a Gray Lustre car it's "W"). BTW, I didn't mention the PST and GST which amounts to 15%.
Old Nov 28, 2001 | 05:12 PM
B1GMATT's Avatar
The 20th AE door sills fit. The pedals should fit. I'll be ordering them soon. I don't know about Courtesy for the AE stuff, I've seen/heard of better deals on this forum. As for the FSTB, I really can't see it having enough room to clear the top on the engine. I spoke to someone from Courtesy about it and they told me that there was a problem - but I've also seen posts where people have mentioned that they heard that it fits. I'm going to wait it out until I know someone has it on their 2002.
http://www.nissanparts.cc/ has the AE pedals for cheaper than Courtesy.
Part #18005-4Y900 for gas.
46531-AB010 for auto brake.
46531-AB000 manual trans brake and clutch.
http://www.custommaxima.com/ should have them in stock in about a week. I don't know about the price but he seems to have some good deals on there.
Hope this helps.
Matt
Old Nov 28, 2001 | 07:44 PM
Maximum Velocity's Avatar
Re: Re: Re: Re: Anyone installed these on 2K2?
I'm assuming that you have the AE sils, but was wondering how much you paid, cause I'm in the US and I paid 60 dollars for the four. So the prices are pretty much the same.
Old Nov 28, 2001 | 08:02 PM
mphman's Avatar
Courtesy FSTB
I have installed the FSTB on my 2K2 SE, and had no problems. I did however have to rotate the middle bar forward slightly to avoid pinching the left windshield washer hose off (would not squirt washer fluid otherwise).
3800 miles, not a squeak or a rattle, and over 28MPG. What a car!
Old Nov 29, 2001 | 11:03 PM
emax02's Avatar
I just ordered AE side sills for $49.59 shipped!! You can't beat that price! Heres the link to the site: https://www.nissan-accessories.com/PP.asp?PID=278 . Looks like the side sills are cheaper in the US then in Canada after all .
Old Nov 29, 2001 | 11:08 PM
MichaelAE's Avatar
I thought the 2K2 came with the drilled pedals and the chrome sills.
Old Nov 29, 2001 | 11:15 PM
emax02's Avatar
2K2 6spd HLSD equipped maximas come with "drilled pedals"{There not out yet though}.
2K2's deffinatly don't come with door sills, only 2K1 AE max's got aluminum door sills.
Old Nov 30, 2001 | 12:35 AM
Max2000's Avatar
always check with
Tustin Nissan for the nissan part.. they have very good prices... check them out under the group deal section....
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
